martulik
Příspěvek od martulik » 20 led 2013, 09:48
Ahoj, můžu taky poprosit?
W0L0XCF6814280074
Děkuji 8-)
Příspěvek od vojtavojta » 20 led 2013, 10:45
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
X:Corsa
C:Corsa
F68:5-DV. SEDAN
1:2001
4:Zaragoza
280074:SERIAL NUMBER
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AJ3 = PRO BEZPEČNOSTNÍ VAK U ŘIDIČE
AT0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,CELÁ
AT7 = PÁS,ZADNÍ SEDADLO,STŘED,3 BODY
CL2 = PRO ČESKOU REPUBLIKU
CS0 = PRO ČESKOU REPUBLIKU
CS0
LHD = ŘÍZENÍ LEVÉ
LW3 = MOTOR BENZINOVÝ 10
M24 = RUČNÍ PŘEVODOVKA,5RYCHLOSTNÍ,TYP F13, ÚZKÝ PŘEVOD
N71 = KOLO,VOZOVKA,OCEL,15 OTVORŮ,5JX13
NT4 = EMISE,EEC 05
QDL = PNEUMATIKY,155/80 R 13-79T
XA3 = OPEL
renek18
Příspěvek od renek18 » 23 led 2013, 18:24
zdravim muzu poprosit o info?
Vin:W0L0AHM757G080004
OPEL ZAFIRA B Z18XER 103kW 2007 cosmo LPG OP-COM MKJ
Příspěvek od vojtavojta » 23 led 2013, 18:49
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
7:2007
G:Gliwice
080004:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
2H0 = MOTOR BENZINOVÝ C18SEL[2H0],Z18XER[2H0],A18XER[2H0]
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
4AU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AV4 = DĚLENÉ ZADNÍ SEDADLO
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B70 = KRYT PRAHU DVEŘÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ
BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ
BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ
BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C61 = SEMI-AUTOMATICKÁ KLIMATIZACE
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CU3 = PRO FRANCII
CU3
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K09 = ALTERNÁTOR,120AMP
K34 = REGULÁTOR RYCHLOSTI
KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OHB
PXF = LEM,ALFA/VINYL
QGF = PNEUMATIKY,205/55 R 16-91H
QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TN6 = BATERIE,55AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
TTO = RÁDIO CHLADICÍ SYSTÉM
U07 = HOUKAČKA,TROUBA
U3D
U55
U68 = INFORMAČNÍ POČÍTAČ
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UJ3
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW6 = REPRODUKTOR,6
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
V4M = VYBAVENÍ 5-STAR,SADA NCAP
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VG9 = OCHRANNÍ VOSK
VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ
VK8 = DRŽÁK,BRÝLE
W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XK2 = PRO FRANCII
Z0W = PRO FRANCII
Z0W
Z1F = RYCHLOMĚR KM/H
Bazil
Příspěvek od Bazil » 24 led 2013, 17:53
Mačkám čepicu v ruce a taky prosím :) On to bude těžkej basic a tudíž kratkej výpis ale díky moc :)
W0L0AHL3562220637
Opel Astra H Caravan 1.6 Z16XEP 2007
Příspěvek od vojtavojta » 24 led 2013, 18:24
W0L:General Motors
A:Astra Platform
L35:Estate
6:2006
1RU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
BA9 = CHLADNIČKA
BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR
C68 = PRO ELEKTRONICKOU KLIMATIZACI
CR7 = PRO MAĎARSKO
CR7
DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA
DP6 = TĚLESO
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FZM = NÍZKONÁKLADOVÁ STRUKTURA MODUL PŘEDNÍ ZÓNY
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
LHD = ŘÍZENÍ LEVÉ
LJ7 = MOTOR Z16XEP[LJ7]
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
T9W = OBKLAD,VNITŘNÍ,TABITA
TN6 = BATERIE,55AH
U3F
U66 = REPRODUKTOR,7
U71 = ANTÉNA,ÚPLNÁ,STŘECHA
UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UEQ = ODPOJOVAČ AKUMULÁTORU
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
VDR
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
Příspěvek od power2 » 31 led 2013, 21:06
Nevíte někdo, kde zjistit cenu dílu, když ho nenajdu ani tady http://servis.opel.cz/otc/cenik.xhtml ? hledám kolik stojí tady ten bazmek 8972943, což je svítilna nákladovýho prostoru
Příspěvek od Pepino_GH » 31 led 2013, 21:18
Dáváš špatné číslo.. Podle tohodle čísla to v ceníku nenajdeš.
Správně je to 17 47 040 a cena je 330,33
Příspěvek od Frydex » 31 led 2013, 21:23
Ty sis našel číslo dílu.. musíš hledat číslo kategorie...nebo kod dílu a to je 1747040 -
Kód dílu 1747040
Název dílu 0-SVITILNA
Cena bez DPH 273 Kč
Cena s DPH 330,33 Kč
DPH 21.0 %
Příspěvek od Pepino_GH » 31 led 2013, 21:24
Zase jsi byl druhej.. :| :lol: :lol:
