Příspěvek od vojtavojta » 10 led 2013, 15:51
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
231477:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
4DU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO
AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
ALR
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BA9 = CHLADNIČKA
BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE
BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE
BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CR7 = PRO MAĎARSKO
CR7
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LPM = VZNĚTOVÝ MOTOR Z19DT[LPM]
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N52 = VOLANT,TŘI PAPRSKY
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
QGF = PNEUMATIKY,205/55 R 16-91H
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9M = ČALOUNĚNÍ ELBA
TM7 = BATERIE,60AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
U3F
UA6 = OCHRANA PROTI VLOUPÁNÍ
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UD7 = ČIDLO PARKOVACÍHO SYSTÉMU
UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU
UJ3
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
VG9 = OCHRANNÍ VOSK
VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE
VNF = ODPOJOVAČ BATERIE
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1F = RYCHLOMĚR KM/H
Z1O = PRO MAĎARSKO
maro
Příspěvek od maro » 10 led 2013, 16:50
mnohokrat diki.
Radoš92
Příspěvek od Radoš92 » 11 led 2013, 23:21
Prosím Opel Zafira
W0L0AHM7562030159
Příspěvek od Frydex » 11 led 2013, 23:45
REGISTRAČNÍ ČÍSLO: CX887GY Datum výroby: 20050926 Značka: Opel Vauxhall VIN: W0L0AHM7562030159 Kód modelu: 0QP75 Kód balení: LD66
Z19DT
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
6:2006
2:Bochum
030159:SERIAL NUMBER
1RU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
80I = VNITŘEK-ČERNÝ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
AE4 = PRO SPORTOVNÍ SEDADLA
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AQ2 = SÍŤ KOMFORTNÍ
AV4 = DĚLENÉ ZADNÍ SEDADLO
AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B70 = KRYT PRAHU DVEŘÍ
BA9 = CHLADNIČKA
BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ
BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ
BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ
BOC = VYROBENÉ V BOCHUM
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
CT6 = PRO ITÁLII
CT6
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU)
JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
LHD = ŘÍZENÍ LEVÉ
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OHB
PXF = LEM,ALFA/VINYL
QGT = PNEUMATIKY,225/45 R 17-91V QL7 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,7JX17
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TM7 = BATERIE,60AH
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
U07 = HOUKAČKA,TROUBA
U3B
U55
U68 = INFORMAČNÍ POČÍTAČ
UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2
UEQ = ODPOJOVAČ AKUMULÁTORU
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UJ3
ULR = ZAPALOVAČ CIGARET,ZADNÍ,LOKETNÍ OPĚRKA
UW6 = REPRODUKTOR,6
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
V4M = VYBAVENÍ 5-STAR,SADA NCAP
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VK8 = DRŽÁK,BRÝLE
W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU
W4Y
XA3 = OPEL
XK4 = PRO ITÁLII
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0H = PRO ITÁLII
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Z1Y = BARVA,DVA POVLAKY
Thom
Příspěvek od Thom » 16 led 2013, 09:37
ahoj, prosím o info na tyhle dvě Astry a předem děkuji :)
1) W0L0AHL4888001345
2) W0L0AHL4892001421
Astra H 1,8 XER 103kW
facelift 2008, Sport packet
hatchback
Příspěvek od vojtavojta » 16 led 2013, 14:27
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
8:2008
8:Ellesmere Port
001345:SERIAL NUMBER
4CU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
C61 = SEMI-AUTOMATICKÁ KLIMATIZACE
CT9 = PRO ŠPANĚLSKO
CT9
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
G61 = 4 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K34 = REGULÁTOR RYCHLOSTI
LHD = ŘÍZENÍ LEVÉ
LJ7 = MOTOR Z16XEP[LJ7]
MPV = PŘEVODOVKA S RUČNÍM ŘAZENÍM F13 (CR)
NT4 = EMISE,EEC 05
RCK = KOLO 16X6.5, HLINÍK, 7 DVOJITÝCH PAPRSKŮ, STYLOVÉ
T9W = OBKLAD,VNITŘNÍ,TABITA
TN6 = BATERIE,55AH
TTX
U3E
U55
U66 = REPRODUKTOR,7
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UJ3
W4Y
W9S = PRO ŠPANĚLSKO
XA3 = OPEL
Z0T = PRO ŠPANĚLSKO
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
9:2009
2:Bochum
001421:SERIAL NUMBER
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
C60 = KLIMATIZACE
CR7 = PRO MAĎARSKO
CR7
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
JL9 = ABS
LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
NT4 = EMISE,EEC 05
TN6 = BATERIE,55AH
U3F
UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA
UJ3
VG9 = OCHRANNÍ VOSK
W4Y
W5T = ODZNAK MOTORU,VYNECHÁN
WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
Thom
Příspěvek od Thom » 16 led 2013, 21:24
tak ta první je opravdu jenom 77kW a ne 85 jak udává prodejce v inzerátu... fňuk fňuk :(
každopádně děkuji za info...
hatchback
Josef
Příspěvek od Josef » 16 led 2013, 21:43
Prosím, prosím Zafira B, W0L0AHM75D2002534
a Zafira A, W0L0TGF75Y2051549
díky, Josef
Zafira B, 1.8, 103 kW, Enjoy
Thom
Příspěvek od Thom » 16 led 2013, 22:40
prosím prosím ještě jedna Astra H W0L0AHL4888000867
děkuji! 8-)
hatchback
Příspěvek od vojtavojta » 17 led 2013, 19:16
Josef píše:Prosím, prosím Zafira B, W0L0AHM75D2002534
díky, Josef
W0L:General Motors
0:Normal Vehicle
A:Astra Platform
D:Unknown
2:Bochum
002534:SERIAL NUMBER
Zbytek me to hlasi ze nebyl nalezen :(
13L = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
20X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - MODRÉ
2F3 = RÁDIO,CAR 400
2H9 = 18 BENZÍNOVÝ MOTOR
80I = VNITŘEK-ČERNÝ
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
A31 = ELEKTRICKÉ OVLÁDÁNÍ OKEN
A50 = MODELY UVEDENÉ DO ROKU 2000 = SPORTOVNÍ SEDADLA, MODELY UVEDENÉ OD ROKU 2000 = KOMFORTNÍ SEDADLA
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AG4 = PŘEDNÍ SEDADLO,LEVÉ,REGULÁTOR VÝŠKY,RUČNÝ
AG5 = PŘEDNÍ SEDADLO,PRAVÉ,REGULÁTOR VÝŠKY,RUČNÝ
AJ3 = PRO BEZPEČNOSTNÍ VAK U ŘIDIČE
AJ4 = PRO BEZPEČNOSTNÍ VAK
AP0 = PRO BOČNÍ VZDUCHOVÝ POLŠTÁŘ,LEVÝ
AP1 = PRO BOČNÍ VZDUCHOVÝ POLŠTÁŘ,PRAVÝ
AP9 = SÍŹ NÁKLADOVÉHO PROSTORU
AT0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,CELÁ
AU0 = ZÁMEK DVEŘÍ,S DÁLKOVÝM OVLÁDÁNÍM
AY3 = OPĚRKA HLAVY,PŘEDNÍ,TEXTIL,CELÁ
B39 = KOBEREC ZADNÍ NÁKLADOVÉ PODLAHY
B73 = SDRUŽENÝ PŘÍSTROJ,BÍLÝ
BB7 = POUŽÍT S CHROMOVÝMI VNITŘNÍMI DVEŘNÍMI KLIKAMI
C60 = KLIMATIZACE
C87 = ČTENÁŘSKA LAMPIČKA,ZADNÍ
CT3 = PRO NĚMECKO
CT3
D40 = STÍNÍTKO PROTI SLUNCI,SE ZRCADLEM,STRANA PASAŽÉRA
D44 = KRYT,POUZDRO NA ZRCADLO,STANA PASAŽÉRA,BARVENÉ
DA5 = LOKETNÍ OPĚRKA,ZADNÍ,STŘED
DL8 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ
GT6 = POMĚR NÁPRAVY 4.19
JL9 = ABS
KC5 = ZÁSUVKA,ELEKTRICKÉ PŘÍSLUŠENSTVÍ(12V)
LHD = ŘÍZENÍ LEVÉ
MG4 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,SPORTOVNÍ
N33 = PRO NASTAVITELNÝ SLOUPEK ŘÍZENÍ
N40 = POSILOVAČ ŘÍZENÍ, BEZ PROMĚNNÉHO POMĚRU
NA5 = EMISE,3 SMĚROVÝ KATALYTICKÝ KONVERTOR,VARIANT 2
NP5 = VOLANT,KŮŽE
OEY
P34 = KOLO A PNEUMATIKA,NÁHRADNÍ
QD9 = KOLO,VOZOVKA,HLINÍK,6 PAPRSKŮ,6JX15
QHL = PNEUMATIKY,195/65 R 15-91H
T6V = PANEL VYBAVENÍ,VNITŘNÍ,S/LUX,VARIANT 2
TN6 = BATERIE,55AH
U16 = PŘÍSTROJ,TACHOMETR
UZ8 = REPRODUKTOR,8 BOSE
V22 = MŘÍŽKA,CHLADIČ,CHRÓMOVÁ LIŠTA
V55 = NOSNÍK STŘECHY
W3X = MOTOR,SZENTGOTTHARD
W4Y
W5P = ZAŘÍZENÍ,NÁKLAD
W6V = VYBAVENÍ,TEXTIL,S/LUX,VARIANT 2
W8X = DODATEČNÉ ČÁSTI, RÁDIO INSTALACE
W9U = DINKS
XA3 = OPEL
XG3 = PRO NĚMECKO
XK5 = ZAŘÍZENÍ,ŠPERK
XK7 = PÍSMO,BEAUTY
XL0 = ZAŘÍZENÍ,VÝBĚR
XR2 = ŠTÍTEK,ELEGANCE
Z0F = PRO NĚMECKO
Z0F
ZQ9 = VNĚJŠÍ VYBAVENÍ,ČERNÉ
