Příspěvek
od swabel » 02 úno 2012, 22:57
VIN: W0L0AHL4858146481
Kód modelu: 0T 48
Kód balíka: LN64
REG: CW811HF
Dátum výroby: 14062005
Typ motora: Z19DTJ
Dátumový kód: 14062005
Čalunenie: XXRY
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
5:2005
8:Ellesmere Port
146481:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
4AU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
ADC = IDENTIFIKACE EFEKTIVNÍ BODOVÉ ŘÍZENÍ-ŘÍDICÍ JEDNOTKA JEDNOTKA CENTRÁLNÍHO ZAMYKÁNÍ DVEŘÍ
AE4 = PRO SPORTOVNÍ SEDADLA
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AIT = PRO DVOUSTUPŇOVÝ AIRBAG
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B70 = KRYT PRAHU DVEŘÍ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BA9 = CHLADNIČKA
BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE
BGZ = IDENT.EFEKTIVNÍ BOD CON.
BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ
BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ
BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CT6 = PRO ITÁLII
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4R = PRODEJNÍ BALÍK SADA-COSMO
ECA = KLÍČ
ELL = VYROBENO V PŘÍSTAVE ELLESMERE
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LRA = Z19DTJ[LRA] NAFTOVÝ MOTOR
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OHB
PBF = LEM,ALPHA/MONDIAL
PSL = MOTORÁRNA FMA PRATOLA SERRA, ITÁLIE
QGT = PNEUMATIKY,225/45 R 17-91V
QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TM7 = BATERIE,60AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
U07 = HOUKAČKA,TROUBA
U3B
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UEQ = ODPOJOVAČ AKUMULÁTORU
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UJ3
UJC = SPÍNAČ SPORTOVNÍ REŽIM
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VK8 = DRŽÁK,BRÝLE
W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK
XK4 = PRO ITÁLII
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0H = PRO ITÁLII
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Z1Y = BARVA,DVA POVLAKY
ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Oprav si podpis, Motor mas 88kW 16V Z19DTJ.
