Příspěvek
od mach00 » 02 čer 2011, 16:20
@ drmpedro
VIN: W0L0AHL3562033065
W0L: General Motors
0: VOZIDLO BEZ ZVLÁSTNÍ ÚPRAVY
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
6: 2006
2: Bochum
033065: SERIAL NUMBER
Kód modelu: 0TS35
Kód balení: JM51
REGISTRAČNÍ ČÍSLO: W-77876T
Datum výroby: 29.9.2005
Typ motoru: Z17DTH
Sériové číslo motoru: 01392955
čalounění: XXVQ
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AE4 = PRO SPORTOVNÍ SEDADLA AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BLN = LIŠTA KRYCÍ DVEŘE VNITŘEK BLUDIŠTĚ,CHROMOVÁ BLP = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,MATNĚ CHROMOVANÁ BOC = VYROBENÉ V BOCHUM BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT2 = PRO RAKOUSKO D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) E94 = KRYT ECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K63 = ALTERNÁTOR,110A KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N35 = VOLANT,SPORT,KŮŽE NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHC PHQ = TEXTILNÍ ČALOUNĚNÍ,ALPHA STŘÍBRNÁ/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL3 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,61/2JX16 T67 = BATERIE,70AH T9M = ČALOUNĚNÍ ELBA TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3A U66 = REPRODUKTOR,7 UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VDR VK8 = DRŽÁK,BRÝLE VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7P = ŠTÍTEK,SPORT W9R = PRO RAKOUSKO WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Z0E = PRO RAKOUSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
