svolávací akce INTERCOOLER!
- JohnyBA
Re: svolávací akce INTERCOOLER!
Ak by ti to nechceli spravit tak skus napisat do opla rovno ty. Je to uznana chyba vyrobcom a ak sa to stahuje na tvoje auto tak nevidim dovod co to ma spolocne s najazdenymi km.
Na kolkych sroboch ten intercooler drzi?JohnyBA píše:Mozem potvrdit, vcera mi vymenili v servise chladic. Mal som tiez slaby unik, dolieval som asi tak raz za 2-3 mesiace, zalezalo ako bolo teplo vonku. Chladic bol poskodeny tym srobom z intercooleru. Auto ma 4 roky, druhy majitel a na tu zvolavacku som v servise upozornil ja aby mi to skontrolovali.
Mne sa uvolnil lavy horny srob, ktory drzi intercooler na chladici (pohlad spredu) ale nenasiel som ho, zatial som tam dal nejaky docasny pokial pojdem do Oplu na tu zvolavacku. Akym sposobom bol ten chladic poskodeny srobom? Sa tam niekde zasekol?
Vy ste tam srob mali alebo sa Vam uz tiez vysroboval ako mne, ked ked ste isli na tu zvolavacku?
[/code]Field Remedy: 2405
Subject: Diesel engines, AC condenser, charge air cooler - Get loose
Models: Engines: Option:
Astra-H 2004...2009,Zafira-B 2005...2009 Diesel Engines,Diesel Engines Diesel Engines with MT/MTA,but not Z19DTH
Complaint: AC condenser, charge air cooler get loose, sometimes radiator damaged by fixing screws.
Cause: Fixing screws become loose.
Production: New fixing system has been introduced in production: Bochum: W0L0AHL3592110607, 20-May-2009 Gliwice: W0L0AHL699G076488, 19-May-2009, Antwerp: W0L0AHL4895063962, 19-May-2009 Ellesmere Port: W0L0AHL4898061764, 15-Jun-2009
Remedy:
In case of complaint check and if necessary correct the installation
sequence of the charge air cooler fixation.
The correct sequence is:
1. Radiator; the charge air cooler is mounted to the radiator
2. Charge air cooler bracket; the condensator is mounted on the
charge air cooler
3. Condensator bracket
Install new AC condenser/charge air cooler fixing screws
(Part-No: 11099561/Catalogue-No: 20 48 759)
with self locking nuts
(Part-No: 90424093 / Catalogue-No: 13 41 713)
and apply a tightening torque of 5 Nm.
FunctionalGroup: D - Heating/Ventilation/Air conditioning,J - Engine
Complaint Group: 11 - Loose or Comes off
Trouble Code: None
[/code]
- JohnyBA
Clovece ja som sa na to vobec nepozeral, vlastne ani neviem ako ten intercooler vypada, len mi povedali ze uz poskodil chladic, trosku ho predral a vidia slabe slzenie. to bolo vsetko.
Ahojte chalani.Tak ja som v čera písal do Oplu ohladom tej zvolávačky či tam spadá aj moja Žirafa.A odpísal od tial pán ,že moje auto spadá pod kampaň 10-R-036: Astra H, Zafira B - integrovaný modul sloupku (CIM).Neviete náhodou čo to je ?a či je to bezplatná oprava.Skúsil som ešte teraz napísať tomu pánovi o dalšie info tak som zvedavý.Ďakujem Braňo
1.9 CDTI (88 kW) Z19DT Cosmo, r.2007,AF40-6 AUTOMATICKÁ PREVODOVKA ,
Ide o ukostrenie CIM modulu, tu je o tom tema svolávací akcebranol píše:Ahojte chalani.Tak ja som v čera písal do Oplu ohladom tej zvolávačky či tam spadá aj moja Žirafa.A odpísal od tial pán ,že moje auto spadá pod kampaň 10-R-036: Astra H, Zafira B - integrovaný modul sloupku (CIM).Neviete náhodou čo to je ?a či je to bezplatná oprava.Skúsil som ešte teraz napísať tomu pánovi o dalšie info tak som zvedavý.Ďakujem Braňo
Takze mam po svolavaci akci na intercooler. A vysledek je takovy, pokud mate poskozeny chladic vody vybraci intercooleru, Jedna se o leve horni uchyceni intercooleru na chladic vody. Musi vam servis vymenit i chladic vody. Akce neni omezena starim auta, ani tim kolik ma najeto. Jen musi byt vase auto zahrnuto do akce a musite mit originalni chladic vody. Akce plati do 3. 2013
Astra H 1.7 74 kw r.v. 2007
Ahojte. Takze som majitelom Astry ktora spada do okruhu zvloavacich akcii. najskor v juni mi povedali v servise ze chladic mam zly,ale ze mam auto starsie ako 5 rokov,vraj mi to mozu urobit za 320E plus robota. Odmietol som,a cudujsa svete v systeme oplu som mal nahodene ze chladic mi vymenili.To som zistil az teraz,ked som si znovu preklepol ci na to moje auto nema mat narok.Napisal som priamo importerovi opel a ten mi povedal vraj mi kampan uz urobili.Nakolko som mu vysvetlil ako to bolo,vec zacal riesit a ajhla dnes sa mi z toho daneho servisu ozvalis tym,ze mi objednaju chladic a vymenia mi ho zadarmo. Takze poucenie kym nemusite,do autorizaku ani nahodou!!
Opel Astra H caravan,1.9CDTi Z19DT 88kW,M6,Cosmo black,Sport
Ahojte. Tak dnes som bol u Opla v XX a menili mi chladic vody. Prijimaci technik sa na mna sice usmieval ale videl som ako je naxrany.Prekazil som mu totizto kseft,ked v lete na moje auto napisal vymenu chladica a neurobil ju nakoniec. Teraz ked to mal od importera za ulohu a vyvodzuju z toho dalsie dosledky, uz mi ho menit musel. Pri samotnej vymene som bol,je to ozaj robota na nic. Samotna vymena asi 5 minut,no rozoberanie a skladanie polovice auta otras-naraznik,mriezka,svetla,intercooler,predna stena ,to vsetko som mal z auta vymontovane-vyzeralo ako po buracke . Teraz uz sa tesim novemu chladicu. Informacia pre niekoho,kto by chcel vediet aky je tam original,tak je to DELPHI.
Ahojte
Ahojte
- Georgeisin
Zkušenost ze svolávačky. Před 14 dny jsem byl na Moravě u babičky a domluvil jsem se s jedním klubákem (technikem v Oplu Břeclav), že si vyměníme lampy, on chtěl chrom, já ty černý. Zajeli jsem k němu na dílnu, vyměnily je. Ptal se mě, jestli jsem byl na tý svolávačce na kontrolu chladiče, protože se prodírá, jak na něj doléhá jiná komponenta. Já na to, že jo. On an to mrknul a řekl mi, že chladič sice vyměnili, ale ty distanční podložky, co se tam mají dát, tam stejně nedali, takže to opět doléhá na chladič a ten se za čas opět prodře. Mě přijde, že to dělají schválně, aby měli za pár let zase kšeft.
A to mi ještě tenkrát rušili jeden termín, že prej ty podložky nemají. Pak volali, že už je mají, a pak je tam stejně nedají. Kocourkov.
