Poprosil bych o:
WOLOAHL0855074343
Děkuji předem.
WOLOAHL0855074343
Děkuji předem.
- Frydex
REGISTRAČNÍ ČÍSLO: Datum výroby: 20041122 Značka: Opel Vauxhall VIN: W0L0AHL0855074343 Kód modelu: 0TN08 Kód balení: MV61Nobody píše:Poprosil bych o: WOLOAHL0855074343 Děkuji předem.
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L08:3-DV. SEDAN
5:2005
5:Antwerp
074343:SERIAL NUMBER
1RU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BGZ = IDENT.EFEKTIVNÍ BOD CON. BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE4 = OSTŘIKOVAČ SVĚTLOMETU CL2 = PRO ČESKOU REPUBLIKU COB = VYROBENÉ V ANTWERPÁCH 2 CS0 = PRO ČESKOU REPUBLIKU CS0 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LCF = BENZÍNOVÝ MOTOR Z20LEL LHD = ŘÍZENÍ LEVÉ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OAR OHA = MÍSTNÍ GM Z EUROPE OHA PBE = LEM,TABITA/MALTA,STYLOVÉ QGT = PNEUMATIKY,225/45 R 17-91V QL7 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,7JX17 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPX TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TT6 = REFLEKTOR,XENON U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM VDR W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W5T = ODZNAK MOTORU,VYNECHÁN WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
A je vám jasné, že: "Jak to má kola, nebo kozy, tak s tím budou brzo problémy...."![Obrázek](http://hidentity.org/hid/CZ866441.gif)
Ahoj, jsem asi měsíc čerstvym majitelem, muzu te taky poprosit o info?
vin:W0L0AHM7582174326
Diky moc..
Diky moc..
Zafira B 1.9CDTI,88kW,r.v.2008,Z19DT
Ahoj,
až bude čas prosím o projeti: WOLOAHL3572219192
Btw skvělý forum, už jsem se tu dočetl spousty zajímavých věci, např. o filtru pevných částic..
Díky!
![Zmatený :?](./images/smilies/icon_e_confused.gif)
Díky!
- Frydex
REGISTRAČNÍ ČÍSLO: Datum výroby: 20080419 Značka: Opel Vauxhall VIN: W0L0AHM7582174326 Kód modelu: 0QN75 Kód balení: LD61W0L:General Motorsmaxik57 píše:Ahoj, jsem asi měsíc čerstvym majitelem, muzu te taky poprosit o info?
Diky moc..
A:Astra Platform
M75:Monocab (Zafira)
8:2008
2:Bochum
174326:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK ALR ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ2 = SÍŤ KOMFORTNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CR7 = PRO MAĎARSKO CR7 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
- Frydex
REGISTRAČNÍ ČÍSLO: D-QB 3027 Datum výroby: 20070618 Značka: Opel Vauxhall VIN: W0L0AHL3572219192 Kód modelu: 0TN35 Kód balení: LF62Vojtěch píše:Ahoj,až bude čas prosím o projeti: WOLOAHL3572219192
Btw skvělý forum, už jsem se tu dočetl spousty zajímavých věci, např. o filtru pevných částic..![]()
Díky!
W0L:General Motors
A:Astra Platform
L35:Estate
7:2007
2:Bochum
219192:SERIAL NUMBER
2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW4 = S CHROMOVOU LIŠTOU C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA OMO P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QBE = PNEUMATIKY,205/55 R 16-89V QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 R2D T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTO = RÁDIO CHLADICÍ SYSTÉM U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAJ = GRAFICKÉ INFORMACE - BARVA UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS WFJ = ÚPRAVY VZNĚTOVÉHO MOTORU,ZÁVOD KAISERLAUTERN PRATOLA SERRA WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Re: win
VIN: W0L0AHL4892049317 Kód modelu: 0TN48 Kód balení: GBS1 Datum výroby: 20081203
Typ motoru: Z14XEP
Sériové číslo motoru: 19RM5822
Styl textu: Zvolte jedno: L48
Výrobní číslo:
Kód datumu:
Číslo převodovky:
Kód ozdobné kombinace:
Kód řízení GM*: TABR
Filtr řízení: LHD
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
CR7 = PRO MAĎARSKO
CR7
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
FV2 = KONEČNÝ POHON NÁPRAVY 4.18
G61 = 4 ŠROUB UPEVNĚNÍ KOLA
JM4 = BRZDOVÝ SYSTÉM,KOTOUČ-PŘEDNÍ/BUBEN-ZADNÍ
LHD = ŘÍZENÍ LEVÉ
LJ2 = BENZÍNOVÝ MOTOR Z14XEP
M24 = RUČNÍ PŘEVODOVKA,5RYCHLOSTNÍ,TYP F13, ÚZKÝ PŘEVOD
NT4 = EMISE,EEC 05
PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
TN5 = BATERIE,44AH
U3F
UJ3
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE
VG9 = OCHRANNÍ VOSK
W4Y
WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
Typ motoru: Z14XEP
Výrobní číslo:
Kód datumu:
Číslo převodovky:
Filtr řízení: LHD
80I = VNITŘEK-ČERNÝ
CR7 = PRO MAĎARSKO
CR7
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
TN5 = BATERIE,44AH
U3F
UJ3
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
- Frydex
Re: win
Tak Pepino byl rychlejší než ja.... snad pomohlo... (zrovna jsem měnil baterku v mobilu a ty si mi volal) Marphyho zákonmisut píše:zkus mi zjistit win W0L0AHL4892049317
volal jsem ti ale jsi ---
auto pro známého
![Velmi šťastný :D](./images/smilies/icon_e_biggrin.gif)
