mach00
Příspěvek od mach00 » 03 dub 2012, 14:03
VIN: W0L0XCE75A4146046
W0L: General Motors
X: Corsa
C: Meriva
E75: Monocab (E75)
A: 2010
4: Zaragoza
146046: SERIAL NUMBER
Kód modelu: 0Z 75
Kód balení: I851
1.reg. značka: BE 414262
Datum výroby: 3.2.2010
Typ motoru: Z16XEP
Sériové číslo motoru: 20PC8715
Čalounění: XXWE
Výbava: 18I = OBLOŽENÍ VNITŘNÍHO PROSTORU TMAVĚ UHLOVÁ 18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ 18Y = OZDOBNÁ LIŠTA DVEŘNÍHO PANELU,BAREVNÁ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A32 = ELEKTRICKY ŘÍZENÉ OKNA,PŘEDNÍ AG4 = PŘEDNÍ SEDADLO,LEVÉ,REGULÁTOR VÝŠKY,RUČNÝ AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA AU0 = ZÁMEK DVEŘÍ,S DÁLKOVÝM OVLÁDÁNÍM AWF = S ÚLOŽNOU KAPSOU B40 = ZAKRÝVAJÍCÍ LOŽNÝ PROSTOR,PEVNÝ B59 B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BNG = DVEŘNÍ KRYCÍ LIŠTA VNITŘEK,UHLOVÁ MAZE BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR BYF = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘEK,UHLOVÁ MAZE C60 = KLIMATIZACE C76 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,ZADNÍ ČTVRT,KOMFORTNÍ A DVOJITÁ ČTECÍ C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU C97 CU5 = PRO ŠVÝCARSKO D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ D91 DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDU = ZRCÁTKO,SESTAVA DJ9 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,ŠIROKÉ,PRAVÉ,LEVÉ DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 G62 = 5 ŠROUB UPEVNĚNÍ KOLA GBJ = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ GDI = TEXTILNÍ ČALOUNĚNÍ,PUNCH/ELBA JBG = PÁKA RUČNÍ BRZDY,CHROM S VYSOKÝM LESKEM JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KIS = KRYTKA,RUKOJEŤ ŘADICÍ PÁKY,S CHROMOVÝM KROUŽKEM LHD = ŘÍZENÍ LEVÉ LJ7 = MOTOR Z16XEP[LJ7] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MPW = PŘEVODOVKA MANUÁLNÍ 5 STUPŇŮ, OPEL, 65 MM, 1.96 2ND, 1.323 3RD 0.946 4TH, 0.756 5TH, F13(WR)(HD) N33 = PRO NASTAVITELNÝ SLOUPEK ŘÍZENÍ NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NP5 = VOLANT,KŮŽE NT4 = EMISE,EEC 05 NZY = KRYT, KOLO OEY OFZ OHA = MÍSTNÍ GM Z EUROPE OHA QLF = PNEUMATIKY,185/60 R 15-88H QQ5 = PRO VELKÉ NÁHRAD.KOLO QT9 = KOLO 15X6, OCEL, 5 PLOCHÝCH PAPRSKŮ T74 T82 = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TEC TN6 = BATERIE,55AH TRP = RÁMEČEK,RADIOPŘIJÍMAČ TTX U3F UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA UJ3 UW6 = REPRODUKTOR,6 VFB = TĚLESO CHRÁNIČE,POŠKOZENÍ PLECHU KRAJNÍHO DÍLU ZADNÍ ČTVRTI VG2 = OCHRANNÍ VOSK, VYNECHEJTE VHC = ZÁCHYTNÝ HÁK PRO NÁKLAD,OPĚRADLO ZADNÍHO SEDADLA VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2N = PÍSMO,LATERAL, VYNECHEJTE W4Y W5T = ODZNAK MOTORU,VYNECHÁN WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XL2 = PRO ŠVÝCARSKO XL8 = PRO FREKVENCI 433 MHZ XM5 = ZAŘÍZENÍ,ÚROVEŇ 1 Z0Y = PRO ŠVÝCARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
milanhc28
Příspěvek od milanhc28 » 09 dub 2012, 06:35
caute mohol by som vas poprosit nech viem co som kupil..
vin: WOLOAHL3555176433
Vopred dakujem
mach00
Příspěvek od mach00 » 09 dub 2012, 20:55
VIN: W0L0AHL3555176433
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
5: 2005
5: Antwerp
176433: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: MB61
Datum výroby: 5.4.2005
Typ motoru: Z20LER
Sériové číslo motoru: 31002357
Čalounění: XXUO
Výbava: 28S = SE SEŠITÍM V TMAVOŠEDÉ BARVĚ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ AE4 = PRO SPORTOVNÍ SEDADLA AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AIT = PRO DVOUSTUPŇOVÝ AIRBAG AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B87 = S ČERNOU KRYCÍ LIŠTOU BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BGZ = IDENT.EFEKTIVNÍ BOD CON. BLN = LIŠTA KRYCÍ DVEŘE VNITŘEK BLUDIŠTĚ,CHROMOVÁ BLP = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,MATNĚ CHROMOVANÁ BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CL2 = PRO ČESKOU REPUBLIKU COB = VYROBENÉ V ANTWERPÁCH 2 CS0 = PRO ČESKOU REPUBLIKU D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KB5 = ASISTENT ROZJEZDU DO KOPCE KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LU2 = BENZINOVÝ MOTOR 20 MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ0 = RUČNÍ PŘEVODOVKA,6RYCHLOSTNÍ (M32-6 WR) N35 = VOLANT,SPORT,KŮŽE NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OBM OHC PBY = ČALOUNĚNÍ ALPHA STŘÍBRNÁ/MALTA QGT = PNEUMATIKY,225/45 R 17-91V QL7 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,7JX17 QQ5 = PRO VELKÉ NÁHRAD.KOLO T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T96 = SVĚTLO DO MLHY PŘEDNÍ T9L = OBKLAD,VNITŘNÍ,MALTA TN6 = BATERIE,55AH TPX TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT6 = REFLEKTOR,XENON U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UA6 = OCHRANA PROTI VLOUPÁNÍ UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UJC = SPÍNAČ SPORTOVNÍ REŽIM VK8 = DRŽÁK,BRÝLE VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7P = ŠTÍTEK,SPORT WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
milanhc28
Příspěvek od milanhc28 » 09 dub 2012, 21:29
Dakujem velmi pekne.. a mal by som otazku co je to: pro dvoustupnovy airbag?
kolko by som tam mal mat vlastne airbagov? dakujem a sorry ze otravujem cawes
zaso
Příspěvek od zaso » 13 dub 2012, 17:03
Nazdar, mohol by som poprosit o vytiahnutie informacii ? W0L0AHL3582048957, dikes.
Opel Meriva 1.7 CDTI 74kW
Příspěvek od Frydex » 13 dub 2012, 21:38
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
048957:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4DU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CR7 = PRO MAĎARSKO CR7 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
zaso
Příspěvek od zaso » 13 dub 2012, 22:59
Dikes moc...
paulinek
Příspěvek od paulinek » 16 dub 2012, 15:02
Mohli byste mi prosím zjistit info? :) VIN: W0L0AHM759G062166 je to Opel Zafira B tak to snad taky zjistíte :) Děkuji mockrát
Zafira B 2009 1.7 CDTi, 92 kW
Příspěvek od Frydex » 16 dub 2012, 15:38
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
9:2009
G:Gliwice
062166:SERIAL NUMBER
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 63U 80I = VNITŘEK-ČERNÝ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT BSI = IDENT.EFEKTIVNÍ BOD CON. BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FTS = KOLÉBKA PRO MOBILNÍ TELEFON FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPL = VZNĚTOVÉ MOTORY Z17DTR,A17DTR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NE9 = EMISNÍ SYSTÉM EEC 09 NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NZX = KRYT,KOLO OHA = MÍSTNÍ GM Z EUROPE OHA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TGR TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V4M = VYBAVENÍ 5-STAR,SADA NCAP VG2 = OCHRANNÍ VOSK, VYNECHEJTE VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WEG = IDENT.EFEKTIVNÍ BOD CON. WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z0F Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Pefox
Příspěvek od Pefox » 16 dub 2012, 23:22
Ahoj,
Mohol, by som poprosit info o tomto aute VIN: W0L0AHL3582030363.
Ďakujem.
