mach00
Příspěvek od mach00 » 23 bře 2012, 16:50
VIN: W0L0AHL3592125303
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
9: 2009
2: Bochum
125303: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: LF61
1. reg. značka: DX898TX
Datum výroby: 25.6.2009
Typ motoru: Z19DTH
Sériové číslo motoru: 17472365
Čalounění: XXVX
Výbava: 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B56 = LIŠTA KYVADLOVÁ KAROSÉRIE BARVA B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BPF = PŘÍPRAVA V NÁRAZNÍKU VPŘEDU,SPODNÍ HRANA SPOJLERU BPG = PŘÍPRAVA V NÁRAZNÍKU VZADU,SPODNÍ HRANA SPOJLERU BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSI = IDENT.EFEKTIVNÍ BOD CON. BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH[LRD] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OCX OER OEZ OFM OHB OMO PXF = LEM,ALFA/VINYL QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTX U07 = HOUKAČKA,TROUBA U3B U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
capone
Příspěvek od capone » 24 bře 2012, 18:02
Taky poprosím info,děkujuuuuuuu 8-)
WOLOAHL3562149208
Myšlenka na ústup je až někde na dně vaší mysli,vlastně tam vůbec není.A tak se pečlivě zakopete.Hluboko.A čekáte."Currahee"
Caponeho Pussy Wagon II 1.6 16V 77KW caravan - https://www.opel-astra-h.cz/forum/viewtopic.php?f=41&t=3188
mach00
Příspěvek od mach00 » 24 bře 2012, 18:28
VIN: W0L0AHL3562149208
W0L: General Motors
A: Astra Platform
L35: Estate
6: 2006
2: Bochum
149208: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: IZS1
1. reg. značka: DW-RH535
Datum výroby: 21.3.2006
Typ motoru: Z16XEP
Sériové číslo motoru: 20GY0261
Čalounění: XXVM
Výbava: 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LJ7 = MOTOR Z16XEP[LJ7] M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U3A U66 = REPRODUKTOR,7 UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VDR VG9 = OCHRANNÍ VOSK W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
SkapalPez
Příspěvek od SkapalPez » 26 bře 2012, 14:27
mohol by som poprosiť
WOLOAHLO885132186
dik
Mike.S
Příspěvek od Mike.S » 26 bře 2012, 18:24
SkapalPez píše:mohol by som poprosiť
WOLOAHLO885132186
dik
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L08:3-DV. SEDAN
8:2008
5:Antwerp
132186:SERIAL NUMBER
vyrobena: 6.5.2008
první RZ: 523CHT44
motor: Z17DTR
č.motoru: 1805920
čalounění: XXVX
výbava:
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE ALR AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CU3 = PRO FRANCII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPL = VZNĚTOVÉ MOTORY Z17DTR,A17DTR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSQ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3D U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 VG9 = OCHRANNÍ VOSK VK8 = DRŽÁK,BRÝLE VOD = MŘÍŽKA CHLADIČE,MŘÍŽOVANÁ,ČERNÁ,S CHROMOVANOU TYČÍ VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK2 = PRO FRANCII Z0W = PRO FRANCII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
gavlisson
Příspěvek od gavlisson » 27 bře 2012, 18:28
Mohl bych také poprosit...?
Velký dík
W0L0AHL3582185125
Opel Astra H 1,7CDTi Caravan, 92KW/125HP (r.v.2008)
papak13
Příspěvek od papak13 » 27 bře 2012, 19:27
gavlisson píše:Mohl bych také poprosit...?
Velký dík
W0L0AHL3582185125
W0L:General Motors
A:Astra Platform
L35:Estate
8:2008
2:Bochum
185125:SERIAL NUMBER
typ motoru: Z17DTR
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ALR AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B56 = LIŠTA KYVADLOVÁ KAROSÉRIE BARVA B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPF = PŘÍPRAVA V NÁRAZNÍKU VPŘEDU,SPODNÍ HRANA SPOJLERU BPG = PŘÍPRAVA V NÁRAZNÍKU VZADU,SPODNÍ HRANA SPOJLERU BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPL = VZNĚTOVÉ MOTORY Z17DTR,A17DTR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OCX OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H S89 = KOLO 16X6.5,HLINÍK,5 DVOJITÝCH PAPRSKŮ T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3B U66 = REPRODUKTOR,7 UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
kabi008
Příspěvek od kabi008 » 31 bře 2012, 10:47
Mozem poprosit aj ja? W0L0AHL0855224811
Dakujem
Astra gtc 2.0T
mach00
Příspěvek od mach00 » 31 bře 2012, 14:25
VIN: W0L0AHL0855224811
W0L: General Motors
A: Astra Platform
L08: 3-DV. SEDAN
5: 2005
5: Antwerp
224811: SERIAL NUMBER
Kód modelu: 0T 08
Kód balení: MV63
1.reg.značka: BLK-XS 500
Datum výroby: 6.6.2005
Typ motoru: Z20LEL
Sériové číslo motoru: 31003836
Čalounění: XXLO
Výbava: 28S = SE SEŠITÍM V TMAVOŠEDÉ BARVĚ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ ADC = IDENTIFIKACE EFEKTIVNÍ BODOVÉ ŘÍZENÍ-ŘÍDICÍ JEDNOTKA JEDNOTKA CENTRÁLNÍHO ZAMYKÁNÍ DVEŘÍ AE4 = PRO SPORTOVNÍ SEDADLA AG6 = PRO SEDADLO SE ČTYŘCESTNÝM RUČNÍM REGULÁTOREM AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AIT = PRO DVOUSTUPŇOVÝ AIRBAG AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BGZ = IDENT.EFEKTIVNÍ BOD CON. BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU COB = VYROBENÉ V ANTWERPÁCH 2 CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K07 = PRO NEZÁVISLÉ TOPENÍ K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KB4 = POUŽITO SPOLU S DÁLKOVÝM OVLÁDÁNÍM OHŘÍVAČE KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LCF = BENZÍNOVÝ MOTOR Z20LEL[LCF] LHD = ŘÍZENÍ LEVÉ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OGA = SE SPECIÁLNÍM VOZIDLEM OPEL OHB OIG P38 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,71/2JX18 PAO = LEM,KOŽENÝ MONDIAL QNA = PNEUMATIKY,225/40 R 18-92W T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TN7 = BATERIE,66AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ U07 = HOUKAČKA,TROUBA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM VDR VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
pavel.b1
Příspěvek od pavel.b1 » 31 bře 2012, 14:38
Ahojte mohol by som poprosit aj ja?
VIN: W0L0AHM756G123661
ZafiraB
Dakujem
