diky otas za info aj mne to pripada divne vo vybave nepise podla vinka co mi tu urobili ze ma esp a ani asr ,asr je len v tech.preukaze ale pise ze to ma len abs a vybavu podla ncap-5 star vyrobena bola v polsku a pre belgicko ,pri startovani mi neukazuje zeby tam bolo esp iba ak by to bolo spojene z abs tazko povedat ale dakujem je tam aspon nejaka pomoc po slovenskych cestach sa to zide hoc je to len asr
opel zafira b 88kw 8v DPF 2007 enjoy
- Mike.S
dekódujeme pomocí EPCKubo píše:Ahoj mohol by som poprosit o info VIN:W0L0AHL3582056026.Podla akeho programu zistujete tieto info TIS alebo EPC alebo nieco ine??Dakujem
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
056026:SERIAL NUMBER
vyrobena: 26.10.2001
motor: Z19DT
č.motoru: 5772473
čalounění: XXVX
výbava:
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT1 = PRO BELGII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ R2F T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ TTO = RÁDIO CHLADICÍ SYSTÉM TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3C U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UJ3 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XK1 = PRO BELGII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0D = PRO BELGII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Škoda 120L
Actual car:
Můžu taky poprosit W0L0AHL48451475 Díky
- Mike.S
Mrkef: můžeš, ale dej ho celé, chybí poslední dvě čísla
Old cars:
Škoda 120L
Actual car:
Škoda 120L
Actual car:
W0L0AHL4845147599 Sry jsem se úplně přehlídl v absolutním nadšení,že jsem našel toto fórum,když mam techničák po ruceMike.S píše:Mrkef: můžeš, ale dej ho celé, chybí poslední dvě čísla
VIN: W0L0AHL4845147599
Kód modelu: 0TS48
Kód balení: KS51
REGISTRAČNÍ ČÍSLO:
Datum výroby: 20040315
Typ motoru: Z18XE
Sériové číslo motoru: 20CU3404
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
4:2004
5:Antwerp
147599:SERIAL NUMBER
2H9 = 18 BENZÍNOVÝ MOTOR
4PU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
AE4 = PRO SPORTOVNÍ SEDADLA
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
BA9 = CHLADNIČKA
BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE
BLN = LIŠTA KRYCÍ DVEŘE VNITŘEK BLUDIŠTĚ,CHROMOVÁ
BLP = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,MATNĚ CHROMOVANÁ
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
CL2 = PRO ČESKOU REPUBLIKU
CS0 = PRO ČESKOU REPUBLIKU
D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY
JL9 = ABS
K09 = ALTERNÁTOR,120AMP
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
N35 = VOLANT,SPORT,KŮŽE
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OAT
OHC
PAT = LEM,VENT/MALTA
QL3 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T9L = OBKLAD,VNITŘNÍ,MALTA
TN6 = BATERIE,55AH
TPX
U3F
U66 = REPRODUKTOR,7
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UEQ = ODPOJOVAČ AKUMULÁTORU
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UJ3
UJC = SPÍNAČ SPORTOVNÍ REŽIM
VG9 = OCHRANNÍ VOSK
VK8 = DRŽÁK,BRÝLE
VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT
W4Y
W7P = ŠTÍTEK,SPORT
XA3 = OPEL
XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK
ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Kód modelu: 0TS48
Kód balení: KS51
REGISTRAČNÍ ČÍSLO:
Typ motoru: Z18XE
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
4:2004
5:Antwerp
80I = VNITŘEK-ČERNÝ
BA9 = CHLADNIČKA
DP6 = TĚLESO
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
OAT
OHC
TN6 = BATERIE,55AH
TPX
U3F
U66 = REPRODUKTOR,7
UJ3
VG9 = OCHRANNÍ VOSK
VK8 = DRŽÁK,BRÝLE
W4Y
W7P = ŠTÍTEK,SPORT
XA3 = OPEL
Mohl bych znát cenu poličky do kastlíku v háčku? Díky
- Mike.S
POLICE, ANTRACITOVÁ ČERŇ, LSŘ: 1 12 820, cena 176,- Kč
Old cars:
Škoda 120L
Actual car:
Škoda 120L
Actual car:
Mohu požádat o katalogové číslo chladiče klimatizace (kondenzátor), orientačně také chladič chladící kapaliny na motor Z16XEP 10/2006. Děkuji
- Mike.S
předpokládám, že je to na Astru ...
CHLADIČ KLIMATIZACE S ODVODŇOVACÍ NÁDRŽKOU ÚPLNÝ (IDENT WC1): 18 50 096
CHLADIČ ÚPLNÝ (IDENT XG1) (POUŽITO U PŘEVODOVKY MECHANICKÉ NEBO EASYTRONIC): 13 00 266
Old cars:
Škoda 120L
Actual car:
Škoda 120L
Actual car:
