řekni si o info podle svého VIN zde
Radoš92
Příspěvek od Radoš92 » 05 dub 2018, 00:54
Prosím o VIN W0L0AHM7562107227
Příspěvek od vojtavojta » 05 dub 2018, 06:33
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
6:2006
2:Bochum
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
2H0 = MOTOR BENZINOVÝ C18SEL[2H0],Z18XER[2H0],A18XER[2H0]
3KU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
AE4 = PRO SPORTOVNÍ SEDADLA
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AV4 = DĚLENÉ ZADNÍ SEDADLO
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B70 = KRYT PRAHU DVEŘÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ
BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ
BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ
BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C61 = SEMI-AUTOMATICKÁ KLIMATIZACE
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE4 = OSTŘIKOVAČ SVĚTLOMETU
CT6 = PRO ITÁLII
CT6
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K34 = REGULÁTOR RYCHLOSTI
K60 = ALTERNÁTOR,100AMP
KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OGI
OHB
PXF = LEM,ALFA/VINYL
QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TN6 = BATERIE,55AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
U07 = HOUKAČKA,TROUBA
U3B
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UD5
UEQ = ODPOJOVAČ AKUMULÁTORU
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
V4M = VYBAVENÍ 5-STAR,SADA NCAP
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VG9 = OCHRANNÍ VOSK
VK8 = DRŽÁK,BRÝLE
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XK4 = PRO ITÁLII
Z0H = PRO ITÁLII
Z1F = RYCHLOMĚR KM/H
Radoš92
Příspěvek od Radoš92 » 05 dub 2018, 08:00
Díky. Zajímalo by mě, co je ten odpojovač akumulátoru...
Mikal
Příspěvek od Mikal » 05 dub 2018, 12:35
Moc prosím...
W0L0AHM7562107227
W0L0AHM7562194023
Díky
Příspěvek od Stan. » 06 dub 2018, 18:11
bigtime096
Příspěvek od bigtime096 » 07 lis 2018, 19:09
Dobrý den všem! Chci koupit Astru,jednu pěknou jsem našel.Mohu poprosit o dekódovaní VINka?děkuji 8-)
W0L0AHL3562054331
MAX - CZ
Příspěvek od MAX - CZ » 07 lis 2018, 20:33
bigtime096 píše:Dobrý den všem! Chci koupit Astru,jednu pěknou jsem našel.Mohu poprosit o dekódovaní VINka?děkuji 8-)
W0L0AHL3562054331
Značka: Opel
Model: ASTRA-H
Katalogový kód: A04
Kód modelu: 0TN35
Kód balíku: JM54
Modelový rok: 2006
Datum výroby: 28.10.2005
Kód GM*Drive: XXVM
Podvozek: L35
Poloha řízení: L
Motor: Z17DTH
Kód motoru: 01408109
Dodatečné informace
VNITŘEK-ČERNÝ
PŘEDNÍ PROHLOUBENÉ SEDADLO
PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ
KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ
KLIMATIZACE
PRO ITÁLII
KLIKA ÚPLNÁ VNĚJŠÍ
ZRCÁTKO,SESTAVA
SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA
TĚLESO
ENJOY
KRYT
KLÍČ
POMĚR NÁPRAVY 3.95 (PŘEDNÍ)
ABS
ALTERNÁTOR,100AMP
ŘÍZENÍ LEVÉ
VZNĚTOVÝ MOTOR Z17DTH[LPZ]
RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP
VOLANT,TŘI PAPRSKY
PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU
PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
EMISE,EEC 05
MÍSTNÍ GM Z EUROPE OHA
TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
OBKLAD,VNITŘNÍ,TABITA
CHLADIČ PLNICÍHO VZDUCHU
BATERIE,60AH
HOUKAČKA,TROUBA
SPÍNAČ OVLÁDÁNÍ RÁDIA
REPRODUKTOROVÝ SYSTÉM 6,BASE
NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
OCHRANNÍ VOSK
RYCHLOMĚR KM/H
OPEL ZAFIRA A 2,2DTI Y22DTR - OPC line 2005
https://www.sbazar.cz/automilacek
bigtime096
Příspěvek od bigtime096 » 09 lis 2018, 08:06
To MAX-CZ: diky,jde z toho poznat,jestli ma esp? A jeste dotaz,jak jsou pomoci kodu znaceny verze s obycejnym podvozkem a jak s IDS+ ?
Příspěvek od Stan. » 09 lis 2018, 09:16
bigtime096 píše:To MAX-CZ: diky,jde z toho poznat,jestli ma esp? A jeste dotaz,jak jsou pomoci kodu znaceny verze s obycejnym podvozkem a jak s IDS+ ?
Podle výpisu VIN nemá ve výbavě kód FX3 = ESP (elektronický stabilizační program )
ani kód FE4 = IDS+ (Systém pro specielní jízdu a stabilizační vlastnosti IDS+)
bigtime096
Příspěvek od bigtime096 » 16 lis 2018, 15:59
Prosim o info VIN W0L0AHL3552091939. Zajimaji me hlavne 2veci:zda ma ESP a IDS podvozek.nemuzu nic kloudneho najit :cry: diky Vam
