maestro99
Příspěvek od maestro99 » 11 čer 2012, 08:15
Zdravim. Mozem aj ja poprosit o info? VIN W0L0AHL3572124052
Daju sa zistit aj kilomentre? Ci nie?
Dakujem
mach00
Příspěvek od mach00 » 11 čer 2012, 09:23
VIN: W0L0AHL3572124052
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
7: 2007
2: Bochum
124052: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: LD62
1.reg. značka: W-83775U
Datum výroby: 6.2.2007
Typ motoru: Z19DT
Sériové číslo motoru: 5383039
Čalounění: XXVX
Výbava: 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AQ2 = SÍŤ KOMFORTNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU C32 = PRO SYSTÉM QUICKHEAT C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CT2 = PRO RAKOUSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT[LPM] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 T61 = PRO SYSTÉM DENNÍCH SVĚTEL T67 = BATERIE,70AH T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ U07 = HOUKAČKA,TROUBA U3A U66 = REPRODUKTOR,7 UA6 = OCHRANA PROTI VLOUPÁNÍ UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W9R = PRO RAKOUSKO WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WFB = NOVÁ ŘÍDICÍ JEDNOTKA WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Z0E = PRO RAKOUSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Najeté km zjistíš přes diagnostiku.
maestro99
Příspěvek od maestro99 » 11 čer 2012, 09:42
dakujem velmi pekne za promtne odpisanie :-)
Atom
Příspěvek od Atom » 11 čer 2012, 17:17
Ahoj všem ;)
Muzu si prosím taky zažadat o info co jsem to vlastně koupil ? ;)
VIN: W0L0AHL3592053174
Díky Tom
Astra Caravan 1.9 CDTI Z19DTH.
Dlouhodoba 6,5L/Km
Příspěvek od Frydex » 11 čer 2012, 21:11
REGISTRAČNÍ ČÍSLO: OD-MX 131 Datum výroby: 20081209 Značka: Opel Vauxhall VIN: W0L0AHL3592053174 Kód modelu: 0TN35 Kód balení: LF62
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
9:2009
2:Bochum
053174:SERIAL NUMBER
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FTS = KOLÉBKA PRO MOBILNÍ TELEFON FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KB5 = ASISTENT ROZJEZDU DO KOPCE KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OBM OHA = MÍSTNÍ GM Z EUROPE OHA QGT = PNEUMATIKY,225/45 R 17-91V QL7 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,7JX17 T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU TGR TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UJC = SPÍNAČ SPORTOVNÍ REŽIM UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA XA3 = OPEL XG3 = PRO NĚMECKO XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Atom
Příspěvek od Atom » 12 čer 2012, 15:40
:lol: Děkuji jste fajn 8-)
Dlouhodoba 6,5L/Km
mgoc
Příspěvek od mgoc » 15 čer 2012, 14:42
Ahoj.
Mozem aj ja poprosit o info? VIN W0L0AHM756G128797
Dakujem.
langosh
Příspěvek od langosh » 15 čer 2012, 21:26
Ahoj, jsem cerstvym majitelem, muzu te taky poprosit o info?
vin:W0L0AHL3552194514
Diky moc..
Příspěvek od Frydex » 15 čer 2012, 22:04
mgoc píše:... VIN W0L0AHM756G128797 Dakujem.
REGISTRAČNÍ ČÍSLO: Datum výroby: 20060508 Značka: Opel Vauxhall VIN: W0L0AHM756G128797 Kód modelu: 0QN75 Kód balení: KD51
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
6:2006
G:Gliwice
128797:SERIAL NUMBER
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2H0 = MOTOR BENZINOVÝ C18SEL,Z18XER,A18XER 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 82Y = LEM OPLECHOVÁNÍ DVEŘÍ,ŠEDÝ 83X = BARVA ČALOUNĚNÍ SEDADLA BARVA ŠEDÁ STEEL A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C60 = KLIMATIZACE CR7 = PRO MAĎARSKO CR7 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E4Y = ČERNÁ/OCELOVĚ ŠEDÁ E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FZM = NÍZKONÁKLADOVÁ STRUKTURA MODUL PŘEDNÍ ZÓNY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL3 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ U3F U66 = REPRODUKTOR,7 UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG9 = OCHRANNÍ VOSK W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
Příspěvek od Frydex » 15 čer 2012, 22:06
langosh píše:... vin:W0L0AHL3552194514 Diky moc..
REGISTRAČNÍ ČÍSLO: CY810DZ Datum výroby: 20050513 Značka: Opel Vauxhall VIN: W0L0AHL3552194514 Kód modelu: 0TV35 Kód balení: LF64
W0L:General Motors
A:Astra Platform
L35:Estate
5:2005
2:Bochum
194514:SERIAL NUMBER
1RU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO ADC = IDENTIFIKACE EFEKTIVNÍ BODOVÉ ŘÍZENÍ-ŘÍDICÍ JEDNOTKA JEDNOTKA CENTRÁLNÍHO ZAMYKÁNÍ DVEŘÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AIT = PRO DVOUSTUPŇOVÝ AIRBAG AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BGZ = IDENT.EFEKTIVNÍ BOD CON. BKH = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STÍNOVANÉ ŽILKOVÁNÍ DŘEVA BNF = LIŠTA KRYCÍ DVEŘE VNITŘEK,TEXTURA DŘEVA BOC = VYROBENÉ V BOCHUM BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII CT6 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHD PAU = LEM,BRISTOL/AMANA PSL = MOTORÁRNA FMA PRATOLA SERRA, ITÁLIE QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 T96 = SVĚTLO DO MLHY PŘEDNÍ T9K = OBKLAD,VNITŘNÍ,AMANA T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0H = PRO ITÁLII Z0L = ELEGANCE Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
