Ďakujem za info
Pokud muzu taky poprosit: W0L0AHL3592136206
Dekuji
Dekuji
Astra H 1,7CDTI 110Hp@147Hp
Pokud mohu poprosit: W0L0AHL48A2139421
luke_tdi:
W0L:General Motors, 0:VOZIDLO BEZ ZVLDÁSTNÍ ÚPRAVY, A:Astra Platform, H:2004 Platform Generation, L35:Estate
9:2009, 2:Bochum, 136206:SERIAL NUMBER
č. motoru - 1944991, typ motoru Z17DTJ, První REGISTRAČNÍ ČÍSLO: VD287031 Datum výroby: 20090717
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ, 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ, 5EA = SADA PRO SNÍŽENÍ OBSAHU CO2, 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE, 80I = VNITŘEK-ČERNÝ, 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ, 8V2, A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO, AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE, AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA, AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ, AP9 = SÍŹ NÁKLADOVÉHO PROSTORU, AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ, BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT, BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT, BSI = IDENT.EFEKTIVNÍ BOD CON., C32 = PRO SYSTÉM QUICKHEAT
C60 = KLIMATIZACE, C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU, CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM, CU5 = PRO ŠVÝCARSKO, CU5, D75 = KLIKA ÚPLNÁ VNĚJŠÍ, DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO, DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ, DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ, DP6 = TĚLESO, DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ, E4Q = ENJOY, ECA = KLÍČ, FX3 = PROGRAM ELEKTRONICKÉ STABILITY, FX4 = KONEČNÝ POHON NÁPRAVY 3.35, G62 = 5 ŠROUB UPEVNĚNÍ KOLA, GAZ = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ, JL9 = ABS, K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
K34 = REGULÁTOR RYCHLOSTI, KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA, KG9 = ALTERNÁTOR,140A,
LHD = ŘÍZENÍ LEVÉ, LPV = VZNĚTOVÝ MOTOR Z17DTJ,A17DTJ, MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR), N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE, NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ, NT4 = EMISE,EEC 05
NZX = KRYT,KOLO, OER , OEY, OFM, OHA = MÍSTNÍ GM Z EUROPE OHA, QGF = PNEUMATIKY,205/55 R 16-91H
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16, T61 = PRO SYSTÉM DENNÍCH SVĚTEL, T67 = BATERIE,70AH, T9M = ČALOUNĚNÍ ELBA, T9T = 'ECOFLEX', TGR, TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ, TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ, TRP = RÁMEČEK,RADIOPŘIJÍMAČ, TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ, TSQ = OSVĚTLENÍ INTERIÉRU DELUXE, TTX = PRO POMOCNÝ KONEKTOR RÁDIA
U3A, U55, U66 = REPRODUKTOR,7, U68 = INFORMAČNÍ POČÍTAČ, UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3, UJ3, UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH, VG2 = OCHRANNÍ VOSK, VYNECHEJTE, VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT, W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU, W4Y, W5T = ODZNAK MOTORU,VYNECHÁN, WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO, WEG = IDENT.EFEKTIVNÍ BOD CON.
WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA, WTR = DOČASNÁ OPRAVA PNEUMATIKY, XA3 = OPEL, XL2 = PRO ŠVÝCARSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI, Z0Y = PRO ŠVÝCARSKO, Z0Y, Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ,
Diky moc, pocitam ze teda mam quick heat (C32) tak to je super, uz aby bylo auto doma, i kdyz ted uz ten quick heat nebude treba. Octavka mi topi tak po 10minutach jizdy a tedka se spatnym termostatem po 20
opc mlhovky
chtěl bych se zeptat na kolik vyjdou opc mlhovky,jsou to ty na fotkách? pasovali by i mlhovky z astry g opc?a taky za kolik se dá sehnat ten chromovaný kroužek kolem nich a mřížky,popřípadě dokázal by to někdo sehnat za solidní cenu?
- Mike.S
Re: opc mlhovky
SADA-MLHOVKA PŘEDNÍ OPC, VXR, LINE PACK 2: 67 10 027, cena 4.721,- Kč
a je to ta samá jako u Astry G OPC a kluci (má je tuším i manli) dávají tyhle http://www.aci.cz/default.asp?cls=stoitem&stiid=29664 za celkem lidovou cenu
a tady máš ty mřížky a kroužky:
OBKLAD PŘEDNÍHO NÁRAZNÍKU, PRAV. (PRO PŘEDNÍ SVĚTLOMETY DO MLHY): 14 00 374
OBKLAD PŘEDNÍHO NÁRAZNÍKU, LEV. (PRO PŘEDNÍ SVĚTLOMETY DO MLHY): 14 00 373
KROUŽEK, CHROM, SADA (PRO PŘEDNÍ SVĚTLOMETY DO MLHY): 14 00 377
Naposledy upravil(a) Mike.S dne 27 bře 2011, 19:51, celkem upraveno 1 x.
Důvod: jo a sloučil jsem Ti do vlákna k tomu určenému xD
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Škoda 120L
Actual car:
Nerez:
W0L:General Motors, 0:VOZIDLO BEZ ZVLDÁSTNÍ ÚPRAVY, A:Astra Platform, H:2004 Platform Generation, L48:5-DV. SEDAN
A:2010, 2:Bochum, 139421:SERIAL NUMBER
č. motoru: 19UU1363, kód motoru - Z14XEP, Datum výroby: 20100717 VIN: W0L0AHL48A2139421
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ, 80I = VNITŘEK-ČERNÝ, 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ, A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO, AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ, AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA, AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED, B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM, BKV = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,UHLOVÁ, BSO = IDENT.EFEKTIVNÍ BOD CON., BYD = LIŠTA KRYCÍ DVEŘE VNITŘEK,VYNECHEJTE
C60 = KLIMATIZACE, CR7 = PRO MAĎARSKO, D75 = KLIKA ÚPLNÁ VNĚJŠÍ, DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA, DP6 = TĚLESO, FV2 = KONEČNÝ POHON NÁPRAVY 4.18, G62 = 5 ŠROUB UPEVNĚNÍ KOLA
GAZ = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ, JL9 = ABS, K3K = BATERIE,50AH
K60 = ALTERNÁTOR,100AMP, KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA, LHD = ŘÍZENÍ LEVÉ
LJ2 = BENZÍNOVÝ MOTOR Z14XEP, M24 = RUČNÍ PŘEVODOVKA,5RYCHLOSTNÍ,TYP F13, ÚZKÝ PŘEVOD
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU, N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU, NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE, NT4 = EMISE,EEC 05
NZX = KRYT,KOLO, OHG, PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA, QGF = PNEUMATIKY,205/55 R 16-91H
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16, T96 = SVĚTLO DO MLHY PŘEDNÍ, T9M = ČALOUNĚNÍ ELBA
T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU, TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ, U3F, U55, U68 = INFORMAČNÍ POČÍTAČ, UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UJ3, URA = SPÍNAČ OVLÁDÁNÍ RÁDIA, UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE, VG9 = OCHRANNÍ VOSK
W4Y, WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO, XA3 = OPEL, XB2 = PRO MAĎARSKO, XJ9 = PRO MAĎARSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI, Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ, Z1O = PRO MAĎARSKO
Smím taky prosit? Dííky. W0L0AHL0875090309
no nic tak to mě levněji budou stát mlhovky z polska i se žárovkami
ale za blbej plast kolem mlhovek solidní pálka aspoň,že ty kroužky se dají rozumně koupit
