mklino
Příspěvek od mklino » 07 dub 2013, 19:44
Zdravim,
mohol by som poprosit o info k tomuto VIN? W0L0AHL48A5004244
Vopred dakujem.
Příspěvek od jakubino » 07 dub 2013, 19:47
2mklino:
VIN: W0L0AHL48A5004244
Kód modelu: 0TN48
Kód balení: I751
Datum výroby: 03092009
Typ motoru: Z16XER
Sériové číslo motoru: 20NU0398
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
A:2010
5:Antwerp
004244:SERIAL NUMBER
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
80I = VNITŘEK-ČERNÝ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT
BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT
C60 = KLIMATIZACE
CR7 = PRO MAĎARSKO
CR7
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DP6 = TĚLESO
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
GAZ = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
N52 = VOLANT,TŘI PAPRSKY
N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NT4 = EMISE,EEC 05
NZX = KRYT,KOLO
OFM
OHA = MÍSTNÍ GM Z EUROPE OHA
QGF = PNEUMATIKY,205/55 R 16-91H
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9M = ČALOUNĚNÍ ELBA
TN6 = BATERIE,55AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
U3F
UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA
UJ3
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE
VG9 = OCHRANNÍ VOSK
VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1F = RYCHLOMĚR KM/H
Z1O = PRO MAĎARSKO
jan pěchota
Příspěvek od jan pěchota » 07 dub 2013, 21:04
Dobrý večer
zafira B vin: W0L0AHM7562190678
Díky
JP
pupik2
Příspěvek od pupik2 » 07 dub 2013, 21:08
Zdravím
mohl bych také pěkně poprosit o info dle svého vinu.
Ptal jsem se tady na forum jak poznám jestli mám ESP a byl jsem odkázan na tebe.
Předem moc děkuji :D.
VIN-WOLOAHL3592077964
1.7 cdti-74 kw-R.V.2009
Příspěvek od jakubino » 07 dub 2013, 21:18
pupik2:
jasne projedem to, namisto O jsou 0=nuly jo
VIN: W0L0AHL3592077964
Kód modelu: 0TN35
Kód balení: JM52
Datum výroby: 05032009
Typ motoru: Z17DTH
Sériové číslo motoru: 1894039
W0L:General Motors
A:Astra Platform
L35:Estate
9:2009
2:Bochum
4CU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BSI = IDENT.EFEKTIVNÍ BOD CON.
C61 = SEMI-AUTOMATICKÁ KLIMATIZACE
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CR7 = PRO MAĎARSKO
CR7
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ)
JL9 = ABS
K34 = REGULÁTOR RYCHLOSTI
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
LHD = ŘÍZENÍ LEVÉ
LPZ = VZNĚTOVÝ MOTOR Z17DTH[LPZ]
MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP
NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
NT4 = EMISE,EEC 05
PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
TM7 = BATERIE,60AH
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
U3F
U55
U68 = INFORMAČNÍ POČÍTAČ
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z1O = PRO MAĎARSKO
Příspěvek od Frydex » 07 dub 2013, 21:20
vojsko:
REGISTRAČNÍ ČÍSLO: KB-B 3114 Datum výroby: 20060516 Značka: Opel Vauxhall VIN: W0L0AHM7562190678 Kód modelu: 0QN75 Kód balení: LA61
Typ motoru: Z19DT
Sériové číslo motoru: 5012997
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
6:2006
2:Bochum
190678:SERIAL NUMBER
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) FZM = NÍZKONÁKLADOVÁ STRUKTURA MODUL PŘEDNÍ ZÓNY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KCN = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 3.POLOHA LHD = ŘÍZENÍ LEVÉ LPP = Z19DTL NAFTOVÝ MOTOR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H R2D T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TIK = CHLADICÍ SYSTÉM,CHLADIČ PLNICÍHO VZDUCHU TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA U3A U66 = REPRODUKTOR,7 U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UEQ = ODPOJOVAČ AKUMULÁTORU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UWB = PŘÍPRAVA PRO MOBILNÍ TELEFON,BEZ OVLÁDÁNÍ HLASEM A BLUETOOTH V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7Z = ZAŘÍZENÍ,ZIMA WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS WTS = SADA,PNEUMATIKA,OPRAVA PNEUMATIK,INTEGROVANÉ VYBAVENÍ XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z0F Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Příspěvek od Frydex » 07 dub 2013, 21:23
Pupek: ESP nemáš, musel by tam být kód FX3 = PROGRAM ELEKTRONICKÉ STABILITY a to tam nemáš ;)
pupik2
Příspěvek od pupik2 » 07 dub 2013, 21:28
Ještě jednou moc děkuji,a promiň za ty 0.
Příspěvek od jakubino » 07 dub 2013, 21:36
8-) v poradku, rad sem pomohl
gordon-d
Příspěvek od gordon-d » 07 dub 2013, 22:00
Dobrý den,
poprosím také o info dle svého VIN:W0L0AHL3552188225
Díky moc!!
