OP-COM interface flash
Napsal: 05 pro 2013, 00:23
zdravim, mam taky problem a neviem si rady..
zakupil som si uz davnejsie OP-Com z ciny, asi pred tromi rokmi.. neviem presne co za FW, predpokladam ze 1.33, na interface mi pise 090820B.. mam taky problem ze mi nekomunikuje so softom, predtym mi svietila Rx aj Tx tusim, teraz len cervena Power..
myslim ze som urobil test interface s novsim softom (mozno aj originalnym) a interface siel do pupav..
stiahol som si OPComFUT29b, a ked dam chech Version/ID vypise mi toto:
Number of interfaces: 1
Description: OP-COM USB V2
FTDI USB Serial: FTT9R38L
FTDI-ChipID ChipID: 0xF063AEC5
FTDI-ChipID Location ID: 0x211
O***M Serial-Number (calculated): HN51QDDU
O***M FW UPdate Code (calculated): 033V8MAV
Interface opened. Handle: 98446416
Baudrate 500kBit/s
Dataformat 8N1
Flowcontrol NONE
SetChars
Timeout 5 seconds
Set DTR and RTS Low = PIC Reset
DTR low
RTS low
Wait 1 second for reset
Set RTS High = PIC running
RTS high
Wait 1.5 second, so bootloader can start FW...
RX Buffer clear... OK
FW Versions- and Interface ID- request send.
Timeout - is your PIC empty? No Firmware?
Set RTS to LOW = PIC Reset
RTS low
Communication closed. Handle: 98446416
a tiez otvori okno v ktorom chyba Frimware Version..
Je tam iba FTDI USB Serial cislo, FTDI ChipID, FTDI Location ID a Seriove cislo Interface..
Vie mi s tym niekto pomoct? poradit? pravdepodobne by som potreboval cinsky clone FW a tiez odpovedajuci software..
alebo sa mylim?
diky za opdovede..
Baudrate 500kBit/s
Dataformat 8N1
Flowcontrol NONE
SetChars
Timeout 5 seconds
DTR low
RTS low
RTS high
RTS low
alebo sa mylim?
diky za opdovede..
