Potvrzuji u Vectry C GTS 1,9CDTI prevodovka F40, znamej problem, za studena drhne mezi 1-2 a za tepla mezi 2-3, na vectra-c.com opel doporucoval vypustit 3,2litru oleje a napustit 2,4litru noveho. A dale uvedl, ze kdyz se to nezlepsi, uz neni jina moznost.
edit:
There's a known fault with the F40 transmission that it crunches a little when going from 1st to 2nd when the gearbox is cold, and then when it's warmed up it does it from 2nd to 3rd. Shouldn't affect 4th. If it's as I've described, Vauxhall's fix is to remove the 3.2 litres of oil that are in the gearbox and replace it with 2.4 litres, (you can't just remove 0.8 litres, as there's no dipstick for measuring the level). However, Vauxhall also say that if the gearbox already only has 2.4 litres in it, then there's no further fix available.
Ma zkusenost je takova, ze po proplachu prevodovky jsem nalil 2,4 litru oleje a zlepseni je jen nepatrne. Je to o zpusobu razeni, bud radim mezi 1-2 rychle a nebo cekam na neutralu 1-2s, pomale plynule prerazeni za studena neni mozne, vzdy to tam jakoby skrtne a to mi nedela dobre
Za tepla cca po 10km prevodovka radi bez problemu....
