VIN: W0L0AHL3575123821
Kód modelu: 0TN35
Kód balení: LD62
REGISTRAČNÍ ČÍSLO:
Datum výroby: 19022007
Typ motoru: Z19DT
Sériové číslo motoru: 5406709
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
7:2007
5:Antwerp
123821:SERIAL NUMBER
2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BA9 = CHLADNIČKA
BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE
BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE
BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CT1 = PRO BELGII
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K34 = REGULÁTOR RYCHLOSTI
K60 = ALTERNÁTOR,100AMP
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LPM = VZNĚTOVÝ MOTOR Z19DT[LPM]
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N52 = VOLANT,TŘI PAPRSKY
N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
R2F
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T9W = OBKLAD,VNITŘNÍ,TABITA
TM7 = BATERIE,60AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TTO = RÁDIO CHLADICÍ SYSTÉM
U07 = HOUKAČKA,TROUBA
U3C
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
U71 = ANTÉNA,ÚPLNÁ,STŘECHA
UAJ = GRAFICKÉ INFORMACE - BARVA
UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
VDR
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VNF = ODPOJOVAČ BATERIE
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS
WFB = NOVÁ ŘÍDICÍ JEDNOTKA
XA3 = OPEL
XK1 = PRO BELGII
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0D = PRO BELGII
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Kód modelu: 0TN35
Kód balení: LD62
REGISTRAČNÍ ČÍSLO:
Typ motoru: Z19DT
W0L:General Motors
A:Astra Platform
L35:Estate
7:2007
5:Antwerp
80I = VNITŘEK-ČERNÝ
BA9 = CHLADNIČKA
CT1 = PRO BELGII
DP6 = TĚLESO
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
R2F
TM7 = BATERIE,60AH
U3C
U55
U66 = REPRODUKTOR,7
UJ3
VDR
W4Y
XA3 = OPEL
XK1 = PRO BELGII
Z0D = PRO BELGII
- Mike.S
pokud nemáš kabrio tak OMEZOVAČ PŘEDNÍCH DVEŘÍ: 51 60 251
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Škoda 120L
Actual car:
plastový nýt, který drží masku chladiče? v Renocaru v Brně mi prodaly nýt příliš úzký
11 04 880 - NÝT ROZPÍNACÍ, MŘÍŽKA CHLADIČE
- Oťas
mohl bych poprosit o info:
W0L0AHL4845226961
W0L0AHL4845226961
VIN: W0L0AHL4845226961
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L48: 5-DV. SEDAN
4: 2004
5: Antwerp
226961: SERIAL NUMBER
Kód modelu: 0TV48
Kód balení: JM51
1. reg. značka: HH-SX7700
Datum výroby: 7.7.2004
Typ motoru: Z17DTH
Sériové číslo motoru: 01051332
Čalounění: XXQY
Výbava: 28S = SE SEŠITÍM V TMAVOŠEDÉ BARVĚ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA B70 = KRYT PRAHU DVEŘÍ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BKH = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STÍNOVANÉ ŽILKOVÁNÍ DŘEVA BNF = LIŠTA KRYCÍ DVEŘE VNITŘEK,TEXTURA DŘEVA BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM COB = VYROBENÉ V ANTWERPÁCH 2 CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ ECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHD PAU = LEM,BRISTOL/AMANA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2D T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T9K = OBKLAD,VNITŘNÍ,AMANA T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE U07 = HOUKAČKA,TROUBA U3A U66 = REPRODUKTOR,7 UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH UJ3 VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z0L = ELEGANCE Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY
W0L: General Motors
A: Astra Platform
L48: 5-DV. SEDAN
4: 2004
5: Antwerp
Kód modelu: 0TV48
Kód balení: JM51
Typ motoru: Z17DTH
Čalounění: XXQY
- Oťas
děkuji na stotisíckrát....
Ahoj,
mohl bych poprosit o vypis k VINu W0L0ZCF6961028152 ?
Dekuji
Dekuji
VIN: W0L0ZCF6961028152
W0L: General Motors
Z: Vectra
C: Vectra
F69: 4-DV. Sedan
6: 2006
1: Rüsselsheim
028152: SERIAL NUMBER
Kód modelu: 0JF69
Kód balení: KE51
Datum výroby: 5.10.2005
Typ motoru: Z18XE
Sériové číslo motoru: 20GA4414
Čalounění: XXUS
Výbava: 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2H9 = 18 BENZÍNOVÝ MOTOR 2J8 32X = BARVA ČALOUNĚNÍ SEDADLA BARVA UHLOVÁ 32Y = BARVA ČALOUNĚNÍ PLECHOVÉHO VÝLISKU DVEŘÍ UHLOVÁ 5QB 80I = VNITŘEK-ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B2C B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR C60 = KLIMATIZACE CR7 = PRO MAĎARSKO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) EA1 = KAPSA,OPĚRADLO PŘEDNÍHO SEDADLA,LH EA2 = KAPSA,OPĚRADLO PŘEDNÍHO SEDADLA,RH FY2 = KONEČNÝ POHON NÁPRAVY 3.74 JL9 = ABS K60 = ALTERNÁTOR,100AMP LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N45 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHI = MÍSTNÍ GM Z EUROPE OHI PAZ = OBKLAD,VNITŘEK,TUNIS PXA = TEXTILNÍ ČALOUNĚNÍ,CHAMPION/ELBA QD2 = KOLO,DISKOVÉ,ALUMINIUM,61/2JX16 QFA = PNEUMATIKY,215/55 R 16-93H QQ5 = PRO VELKÉ NÁHRAD.KOLO RUE = VYROBENÉ V RUESSELSHEIMU SVB = DRŽÁK ŠÁLKU,ZADNÍ TN6 = BATERIE,55AH TRP = RÁMEČEK,RADIOPŘIJÍMAČ U3F U55 U68 = INFORMAČNÍ POČÍTAČ U91 = ANTÉNA KRÁTKÁ,STŘEŠNÍ,RÁDIO UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 VK8 = DRŽÁK,BRÝLE W2N = PÍSMO,LATERAL, VYNECHEJTE W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO Z1Y = BARVA,DVA POVLAKY
W0L: General Motors
Z: Vectra
C: Vectra
F69: 4-DV. Sedan
6: 2006
1: Rüsselsheim
Kód modelu: 0JF69
Kód balení: KE51
Typ motoru: Z18XE
Čalounění: XXUS
jeste jednou diky!
