Zdravím, prosím o výpis mojí nové Astry. Děkuji. VIN:W0L0AHL3572240496
VIN: W0L0AHL3572240496
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
7: 2007
2: Bochum
240496: SERIAL NUMBER
Kód modelu: 0TN35
Kód balení: JI62
PRVNÍ RZ: RO-FM 1001
Datum výroby: 13.7.2007
Typ motoru: Z17DTR
Sériové číslo motoru: 01661524
Čalounění: XXVM
Výbava:
10U = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPV = VZNĚTOVÝ MOTOR Z17DTJ,A17DTJ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA OMO P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T9W = OBKLAD,VNITŘNÍ,TABITA TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE U3A UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
W0L: General Motors
A: Astra Platform
L35: Estate
7: 2007
2: Bochum
Kód modelu: 0TN35
Kód balení: JI62
Typ motoru: Z17DTR
Čalounění: XXVM
Výbava:
Zdravím všechny, chtěla bych také poprosit o výpis Astry VIN:WOLOAHL4875143536. Děkuji předem.
V tom VIN kódu jsou nuly, ne písmeno O...
VIN: W0L0AHL4875143536
Kód modelu: 0TN48
Kód balení: I752
REGISTRAČNÍ ČÍSLO:
Datum výroby: 20070309
Typ motoru: Z16XER
Sériové číslo motoru: 20JU6707
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
7:2007
5:Antwerp
143536:SERIAL NUMBER
63U
80I = VNITŘEK-ČERNÝ
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
BA9 = CHLADNIČKA
CR7 = PRO MAĎARSKO
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
JL9 = ABS
K09 = ALTERNÁTOR,120AMP
LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
NT4 = EMISE,EEC 05
QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16
T96 = SVĚTLO DO MLHY PŘEDNÍ
TN6 = BATERIE,55AH
U3F
U66 = REPRODUKTOR,7
UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UJ3
V90 = PŘÍPRAVA PRO UPEVNĚNÍ NÁKLADU
VDR
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
Kód modelu: 0TN48
Kód balení: I752
REGISTRAČNÍ ČÍSLO:
Typ motoru: Z16XER
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
7:2007
5:Antwerp
63U
80I = VNITŘEK-ČERNÝ
BA9 = CHLADNIČKA
CR7 = PRO MAĎARSKO
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
TN6 = BATERIE,55AH
U3F
U66 = REPRODUKTOR,7
UJ3
VDR
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
Díky moc...hned je výběr nové Astry jednodušší
Existuje na Z16XEP něco jako čidlo hladiny oleje? Nikde (Elit, AutoKelly...) jsem takový díl nenašel. Pokud ano, prosím o číslo dílu a cenu, pokud ne, jak je to snímaní řešené - na co je kontrolka hladiny oleje napojená?
Hlapci, boční lišty na karavan určené pro lak?
- Mike.S
snímače hladiny oleje jsou tam dvě, bohužel nevím, jaký je v nich rozdíl, zkus mi v SZ poslat VIN, třeba to vyfiltruje a jedno z nich vypadne, co se pak týče zapojení, nemám TIS, ale buď je kontrolka zapojená přímo na čidlo nebo přes RJ, ale to jsem Ti asi moc nepomohl co?emvee píše:Existuje na Z16XEP něco jako čidlo hladiny oleje? Nikde (Elit, AutoKelly...) jsem takový díl nenašel. Pokud ano, prosím o číslo dílu a cenu, pokud ne, jak je to snímaní řešené - na co je kontrolka hladiny oleje napojená?
LIŠTA OCHRANNÁ, ZADNÍ DVEŘE, PRAV., OPATŘENO ZÁKLADNÍM NÁTĚREM: 51 72 416Jocker píše:Hlapci, boční lišty na karavan určené pro lak?
LIŠTA OCHRANNÁ, ZADNÍ DVEŘE, LEV., OPATŘENO ZÁKLADNÍM NÁTĚREM: 51 72 415
LIŠTA OCHRANNÁ, PŘEDNÍ DVEŘE, PRAV., OPATŘENO ZÁKLADNÍM NÁTĚREM: 1 72 721
LIŠTA OCHRANNÁ, PŘEDNÍ DVEŘE, LEV., OPATŘENO ZÁKLADNÍM NÁTĚREM: 1 72 640
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Škoda 120L
Actual car:
- Mike.S
emvee: podle Tvého VINka je to tenhle: 62 35 686, cena v Opelu 2.298,-Kč
zkus Vojtu, ten to umí o 15% míň
co se pak týče toho zapojení, zkus se ho na to zeptat taky, vím, že TIS má
Old cars:
Škoda 120L
Actual car:
Škoda 120L
Actual car:
Mike.S: Díky! Zatím to řešit nebudu, dneska cestou do práce se to nerozsvítilo, oleje je tam dost. Za měsíc jdu na výměnu oleje, tak uvidím, třeba to pak přestane...
