Mike.S
Příspěvek od Mike.S » 06 čer 2011, 20:06
iko11 píše:Tiez keby som mohol poprosit
W0L0AHL3565069719
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
6:2006
5:Antwerp
069719:SERIAL NUMBER
vyrobena: 14.11.2005
první RZ: DC792DP
motor: Z19DT
č. motoru: 4748919
čalounění: XXVX
výbava:
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ AE4 = PRO SPORTOVNÍ SEDADLA AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VG9 = OCHRANNÍ VOSK VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Jirka156
Příspěvek od Jirka156 » 06 čer 2011, 21:17
Můj VIN je W0L0AHM7562055415. Díky.
Mike.S
Příspěvek od Mike.S » 06 čer 2011, 22:01
vyber si: :mrgreen:
VOLANT ÚPLNÝ, S 3 -PŘÍČKOVÝMI KRYTY, KŮŽE, CHARCOAL (SE SEŠITÍM V MODRÉ BARVĚ) (IDENT SLS): 9 13 728
VOLANT ÚPLNÝ, KŮŽE, S 3 -PŘÍČKOVÝMI KRYTY, ČERNÁ KOVOVÁ VÍČKA (TAKATA-PETRI): 9 13 308
VOLANT ÚPLNÝ, KŮŽE, S 3 -PŘÍČKOVÝMI KRYTY, CHARCOAL, D=370MM (IDENT AD): 9 13 319
VOLANT ÚPLNÝ, S 3 -PŘÍČKOVÝMI KRYTY, D=370MM, CHARCOAL, KŮŽE: 9 13 372
tyhle všechny (kromě OPC a VXR) mi zůstaly po filtru dle VIN
Old cars:
Škoda 120L
Actual car:
Tomino
Příspěvek od Tomino » 07 čer 2011, 20:08
to Mach00 díky moc :-)
Opel Astra H caravan 1.7 CDTI 74kw (2008)
Opel Astra G sedan X16SZR (1999) - prodáno
Q-čko
Příspěvek od Q-čko » 07 čer 2011, 20:16
Ahoj prosim vas ake je cislo plata v kufri astra H combi r.v. 2007 je to tusim od firmy BORGERS zhanam cenu alebo aspon tu vrchnu cast len ten koberec .Velka vdaka vsetkym za odpovede
Jirka156
Příspěvek od Jirka156 » 07 čer 2011, 20:40
Já z toho co si psal bych měl mít tedy variantu 3 nebo 4. Je to kůže, multifunkce, černé obšití a krytky takové šedozlaté viz obr.
Mike.S
Příspěvek od Mike.S » 07 čer 2011, 20:52
no, tak potom jeden z nich, ani z výbavy v EPC jsem toho o Tvém volantu víc nedostal, ale jaký je mezi nimi rozdíl ... netuším :oops:
Old cars:
Škoda 120L
Actual car:
Honz@
Příspěvek od Honz@ » 11 čer 2011, 20:07
Můžu poprosit? Výsledek pak do SZ, děkuji 8-)
W0L0AHL35A2035658
Prodáno... Co bude dál? Netuším...
Čibis66
Příspěvek od Čibis66 » 11 čer 2011, 21:50
Můžu taky poprosit :D ať vím co jsem koupil :o DĚKUJI MÓÓÓC WOLOAHM756G157807
Astra F kombi r.v. 1994 1.4 (44 kw)
Yamaha FZ6N 2005 (72 kw)
Zafira B r.v. 2005 1.8 (103 kw)
Mike.S
Příspěvek od Mike.S » 11 čer 2011, 22:01
Honz@ píše:Můžu poprosit? Výsledek pak do SZ, děkuji 8-)
W0L0AHL35A2035658
máš to tam, ale nic moc
Old cars:
Škoda 120L
Actual car:
