Příspěvek od vojtavojta » 17 led 2013, 19:18
Thom píše:prosím prosím ještě jedna Astra H W0L0AHL4888000867
děkuji! 8-)
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
8:2008
8:Ellesmere Port
000867:SERIAL NUMBER
4CU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE
BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE
C61 = SEMI-AUTOMATICKÁ KLIMATIZACE
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CT9 = PRO ŠPANĚLSKO
CT9
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
G61 = 4 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K34 = REGULÁTOR RYCHLOSTI
K60 = ALTERNÁTOR,100AMP
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LJ7 = MOTOR Z16XEP[LJ7]
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MPV = PŘEVODOVKA S RUČNÍM ŘAZENÍM F13 (CR)
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
QQ5 = PRO VELKÉ NÁHRAD.KOLO
RCK = KOLO 16X6.5, HLINÍK, 7 DVOJITÝCH PAPRSKŮ, STYLOVÉ
T9W = OBKLAD,VNITŘNÍ,TABITA
TN6 = BATERIE,55AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TTX
U07 = HOUKAČKA,TROUBA
U3E
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UJ3
VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE
W4Y
W9S = PRO ŠPANĚLSKO
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
Z0T = PRO ŠPANĚLSKO
Z1F = RYCHLOMĚR KM/H
Josef
Příspěvek od Josef » 17 led 2013, 20:57
Prosím, prosím Zafira B, W0L0AHM75D2002534
a Zafira A, W0L0TGF75Y2051549
díky, Josef
W0L:General Motors
0:Normal Vehicle
A:Astra Platform
M75:Monocab (Zafira)
D:Unknown
2:Bochum
002534:SERIAL NUMBER
Zbytek me to hlasi ze nebyl nalezen
Je asi moc mladá, cca 2 měsíce, přesto mě zajímalo jakou má papírovou výbavu. :(
Díky moc za ochotu.
Josef
Zafira B, 1.8, 103 kW, Enjoy
Thom
Příspěvek od Thom » 17 led 2013, 22:21
díky vojtovojto :)
Astra H 1,8 XER 103kW
facelift 2008, Sport packet
hatchback
RomanK
Příspěvek od RomanK » 17 led 2013, 23:07
Josef píše:Je asi moc mladá, cca 2 měsíce, přesto mě zajímalo jakou má papírovou výbavu. :(
Díky moc za ochotu.
Josef
W0L0AHM75D2002534
Typ motoru: A18XER
Sériové číslo motoru: 20SL6756
Kód datumu: 25082012
Kód čalounění: TABR
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ
2H0 = MOTOR BENZINOVÝ C18SEL[2H0],Z18XER[2H0],A18XER[2H0]
80I = VNITŘEK-ČERNÝ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD
AQ2 = SÍŤ KOMFORTNÍ
AV4 = DĚLENÉ ZADNÍ SEDADLO
AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT
BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C68 = PRO ELEKTRONICKOU KLIMATIZACI
CR7 = PRO MAĎARSKO
CR7
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DP6 = TĚLESO
E4Q = ENJOY
E9D = POTAH,ZAROVNANÝ,KOLO,VARIANT 1
ECA = KLÍČ
FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
GWH = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
JL9 = ABS
KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
NE9 = EMISNÍ SYSTÉM EEC 09
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9M = ČALOUNĚNÍ ELBA
T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU
TN6 = BATERIE,55AH
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
TTX = PŘÍVOD POMOCNÉHO KONEKTORU VÝBAVY RÁDIA
U3F
U55
U66 = REPRODUKTOR,7
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
V48 = CHLAZENÍ,MAXIMÁLNÍ OCHRANA
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT
W4Y
WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z1O = PRO MAĎARSKO
Příspěvek od vojtavojta » 18 led 2013, 19:38
No jo,nekdo umi vic :) 8-) 8-) 8-)
Josef
Příspěvek od Josef » 18 led 2013, 21:55
RomaneK, díky moc, aspoň vím co jsem koupil, jen mě děsí slova PRO MAĎARSKO a VG2 = OCHRANNÍ VOSK, VYNECHEJTE . Tím voskem se myslí konzervace dutin nebo ochranný vosk na povrch auta, nevíš?
Auto je koupené u nás a funglovka, jako skladový vůz.
Díky, Josef
Příspěvek od Pepino_GH » 18 led 2013, 22:32
Josef - pro Maďarsko jsou všechny pro východní Evropu, je tam pro tuto lokaci centrální sklad.. A vosk si myslím, že je to tak, jak jsi napsal, tedy ta druhá varianta. Ale bývá to psané i u aut pro Německo apod.
Příspěvek od Pepino_GH » 18 led 2013, 22:35
Já mám u Merivy toto - VG9 OCHRANA - VOSK, VNĚJŠEK KAROSÉRIE
Zemi mám také Maďarsko..
Josef
Příspěvek od Josef » 18 led 2013, 22:56
Pepino, díky, už můžu jít v klidu spát 8-)
Příspěvek od Pepino_GH » 18 led 2013, 22:57
Není zač.. ;)
