Opel EPC, chyba pri spusteni
nero
Příspěvek od nero » 26 zář 2011, 20:42
Zdravim, mam taky progblem z nicoho nic mi nejde spustit EPC, pouzival som ho bez problemov a jedneho dna mi napise toto ked to chcem spustit, vid screen .
Kód: Vybrat vše
http://img99.imageshack.us/img99/5663/94846506.jpg
a neviem ako to opravit, reinstall nepomaha, pretoze ked som to instaloval postupom kt. bol na stranke :
Installation:
1. We take the image, mount in any way, take out from it all.
1a. autorun.inf and setup.exe throw into the basket
2. Set GMGInfrastructure \ GMGInfrastructure.msi (Standartalone)
3. Set GMEApplication \ GMEApplication.msi
4. Set GMGLocalDB \ GMGLocalDB.msi
5. Set GMERomDB \ GMERomDB.msi
6. Open the Start menu and execute cmd.exe
and then in the DOS window, run 's TV turns three commands:
SET PATH = "C: \ Program Files \ Snap-on Business Solutions \ Global EPC \ GM \ jre1.6.0_02 \ bin";
cd "C: \ Program Files \ Snap-on Business Solutions \ Global EPC \ GM \ Configurator"
java-jar Configurator.jar
Before their execution must go to the root of drive C: by typing "cd \" without quotes of course, but with a space between cd and \
string takes the form C: \>
And then execute commands very carefully depending on what type or just copy from here. Hot keys in a DOS window Osovski not work, only the mouse.
7. Reboot your computer
8. Open IE and enter the address of the code:
http://127.0.0.1:351/PQMace/launcher.html or http://127.0.0.1:351/PQMace (all different)
... And enjoy a fully working version EPC4
Tak vsetko mi islo, a zrazu to zblblo :/
Dik za help :)
Re: Opel EPC, chyba pri spusteni
Příspěvek od swabel » 26 zář 2011, 23:11
Odporucam pozriet toto vlakno az dokonca:
http://forum.opelclub.sk/viewtopic.php? ... &start=200
