Příspěvek od Pepino_GH » 03 kvě 2011, 22:41
Edds: W0L:General Motors 0:VOZIDLO BEZ ZVLDÁSTNÍ ÚPRAVY A:Astra Platform H:2004 Platform Generation
L48:5-DV. SEDAN 7:2007 8:Ellesmere Port 009077:SERIAL NUMBER
Číslo motoru: 19HT9433 1. REGISTRAČNÍ ČÍSLO: DG008LL Datum výroby: 20060907
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ, 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
80I = VNITŘEK-ČERNÝ, 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ, 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO, AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA, AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ, BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ
C60 = KLIMATIZACE, C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CT6 = PRO ITÁLII, CT6, D75 = KLIKA ÚPLNÁ VNĚJŠÍ, DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA, DP6 = TĚLESO, DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY, ECA = KLÍČ, FV2 = KONEČNÝ POHON NÁPRAVY 4.18, G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS, K60 = ALTERNÁTOR,100AMP, KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ, LJ2 = BENZÍNOVÝ MOTOR Z14XEP, M24 = RUČNÍ PŘEVODOVKA,5RYCHLOSTNÍ,TYP F13, ÚZKÝ PŘEVOD
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU, N52 = VOLANT,TŘI PAPRSKY, NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NT4 = EMISE,EEC 05, OHA = MÍSTNÍ GM Z EUROPE OHA, P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA, QGF = PNEUMATIKY,205/55 R 16-91H
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16, QQ5 = PRO VELKÉ NÁHRAD.KOLO, T9W = OBKLAD,VNITŘNÍ,TABITA
TN5 = BATERIE,44AH, TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ, TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TTO = RÁDIO CHLADICÍ SYSTÉM, U07 = HOUKAČKA,TROUBA, U3B, UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH, UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UJ3, URA = SPÍNAČ OVLÁDÁNÍ RÁDIA, UW6 = REPRODUKTOR,6, W4Y, WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL, XK4 = PRO ITÁLII, Z0H = PRO ITÁLII, Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Edds
Příspěvek od Edds » 04 kvě 2011, 01:31
Vdaka...
cluise
Příspěvek od cluise » 04 kvě 2011, 07:57
thx ;)
iling
Příspěvek od iling » 04 kvě 2011, 09:52
vdaka,
v osvedceni mam uvedeny motor Z19DT a podla VIN Z19DTL,
no nevadi
este raz dakujem
pueblo
Příspěvek od pueblo » 04 kvě 2011, 10:13
Kluci proč u mýho výpisu (dle VIN) není u kódu E4Q (výbava) uvedena žádná hodnota? U někoho je ENJOY, u někoho ten kód není vypsán vůbec a u mě kód je , ale bez obsahu.
Auto mám z dojčlandu a dodnes jsem nezjistit, jakej stupeň výbavy tam je. Tedy byl při koupi, než jsem se vrhnul na vylepšování :mrgreen:
Díky
Příspěvek od Pepino_GH » 04 kvě 2011, 10:21
iling - asi chyba při přihlašování, prostě jim vypadlo L, jinak dle Opel-infos.de je DT 88kW, DTL 74 kW.. oba 8 ventilů..
Příspěvek od Pepino_GH » 04 kvě 2011, 10:23
pueblo: E4Q Paket, Fun, dle výše uvedených stránek, co ale tato výbava znamená..
iling
Příspěvek od iling » 04 kvě 2011, 11:06
vdaka,
16V by bol lepsi:-(
Příspěvek od Pepino_GH » 04 kvě 2011, 14:56
Zase by jsi měl vířivé klapky.. 88 kW by bylo lepší, ale s Tvým datem výroby asi těch 8 ventilů.. :|
solo1976
Příspěvek od solo1976 » 04 kvě 2011, 18:24
Prosím o info pre tento VIN:
W0L0AHL35B2100697
Vopred ďakujem :)
Astra Caravan Classic III 1,6 85kW
