OPCOM - vase skusenosti
- swabel
Re: OPCOM - vase skusenosti
Mne neslo programovat REC s original zakupenym OPCOMom, takze si z toho, ze Ti nejde programovat REC a UEC nic nerob, vsetko zalezi od auta, ci sa mu chce, al nie. Na niektorom ide vsetko, na inom nic, niekde len REC alebo UEC.
Tvoj pripad programovania REC a UEC - len a jedine TechII. Bohuzial OPCOM zatial nie je dokonaly...
Kde se da sehnat program OPCOM v Sk .
- swabel
Dnes po dlhsej dobe opat vysiel novy update pre OP-COM 100315e
Kód: Vybrat vše
OP-COM Release 100315e - What's new
The vehicle list database is updated to MY2010. All of the control units of the new Astra-J is on
the list!
On-line product activation, Install the application, and within 2 minutes, you are ready to use it!
We strengthened our software protection, in order to make more robust, and yet user friendly.
Automated Internet based program update, with a click of a button!
Corsa-D EPS programming, and variant coding supported.
Astra-H, Zafira-B LUK Easytronic CAN Learn Gerbox Parameters, Clutch bleeding, Touch point
adaptation is supported!
Corsa-C, Meriva, Tigra-B Easytronic Learn Gerbox Parameters, Clutch bleeding, Touch point
Astra-H IPC Variant coding, and code index programming.
Astra-H ABS/TC/ESP Variant coding supported.
All of the currently available DIS, and EHU Code, Audio, and Temperature Index programming
is supported.
Astra-H/Zafira-B Speed dependant locking option programming in REC is now possible!
All of the currenty available UHP code index, and other programming option is supported.
Insignia engine code A20DTH full measuring block list added.
Insignia EPB (Electronic Parking Brake) measuring blocks, and adaptations are added.
Modified trouble code handling for the Vectra-C Z28xxx engines.
Improved compatibility for the Insginia, and the Astra-J with older interfaces (Rev. A, and Rev.
B).
New system driver for x64 systems (Vista, and Windows7).
Automated driver installer for both x64, and x86 systems.
Modified layout, now you can use any non-standard DPI settings in the Display Settings panel of
the OS. With older program, DPI settings other than 96 resulted problems in the screen layout.
Added trouble code descriptions for many control units, and corrected several small bugs.
Ze by?
Ale na cinany to jeste nefunguje
Ze by?
This version is the best - many new option but IT`S ONLY FOR LEGALL INTERFACE - NOT FOR CLONE !x-father píše:Astra-H IPC Variant coding, and code index programming.
Ze by?
uvidime mozno casom
pozor na tu posledne spominanu verziu. ak ju spustite s kablom, tak vam vymaze obsah flash na kabli a kabel prestane fungovat aj so starsimi veziami. na opravenie problemu bude nutne naprogramovat programatorom flash novym obsahom.
Astra 08 1.7 CDTI Caravan
- Raptor181
Da sa to opravit aj bez programatora.Tunak píše:pozor na tu posledne spominanu verziu. ak ju spustite s kablom, tak vam vymaze obsah flash na kabli a kabel prestane fungovat aj so starsimi veziami. na opravenie problemu bude nutne naprogramovat programatorom flash novym obsahom.
Opel Astra H Caravan (Stela), Enjoy, 1.6 16V 85kW/115PS, Z16XER
http://www.rfsystem.sk/shop info@rfsystem.sk
Diagnostika, autoelektrika, predaj montáž autoalarmov, LED žiarovky, autožiarovky, LED daylight, tacho, airbag, immo, odkodovanie autoradii.
Taky sem to cet, ze to kabel pokazi. Ale navod jak to opravit jsem nenasel. Kazdopadne to zkouset nebudu
Raptor, swabel mate to odskusane? Ten soft naplni pamat nezmyslami a kabel sa prestane hlasit ako kabel. Ako sa to tada da vyriesit bez programatora?swabel píše:Ano, nahrat novy obsah ide aj bez programatora.
